Question about Frigidaire Refrigerators
Frigidaire side by side Model # PLHS237ZA is not making ice
Not making ice
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
SOURCE: Frigidaire Fridge -- water stopped working
change water filter
Posted on Jul 22, 2009
What year is the PLHS237ZA refrigerator?
Good Morning Friend,
I see that you want to know what year your Frigidaire refrigerator, model# PLHS237ZA, was manufactured. I see that they were first manufactured in 2002 or 2003. I suggest contacting the manufacturer, as they may be able to pinpoint the exact year your refrigerator was made. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire PLHS237ZA Side by Side...
What is the cubic ft for model plhs237za?
The model/serial plate or sticker on the unit should tell you........
Nov 04, 2013 | Frigidaire PLHS237ZA Side by Side...
We have a Frigidaire Model FRS26 ZSEB4 with a clogged drain plug in the freezer. How do we unplug it?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref.
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 06, 2011 | Frigidaire PLHS237ZA Side by Side...
Where do I find the condenser coils on a Frigidaire side by side model PLHA237ZA
I have worked on a few of these. The condenser is under the bottom in the compressor area.
Jul 17, 2011 | Frigidaire PLHS237ZA Side by Side...
How do you vacuum the coils on a Frigidaire side by side model # PLHS237ZA? Is it done from the back?
Most refrigerators have a panel on the back at the base you can unscrew. Use a narrow attachment and be careful not to disturb any wires/hoses. It's pretty easy and you should do it on a regular basis, especially if you have pets.
My ice maker stopped working on my side by side mod. # plhs237za , water dispenser works , filter is new , any help?
You can try one that that I was successful with.
Unplug the entire unit for about a minute and the plug it back in and see if that helps.
Thanks
asnowman
Sep 04, 2009 | Frigidaire Refrigerators
I have a frigidaire model#frs23r4a side by side fridge the ice maker makes very little ice and is not working at all now, any repair suggestions ??
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...thumbs up
Aug 17, 2009 | Frigidaire FRS23R4A Side by Side...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
