Question about Garmin Nuvi 50Lm - Gps Receiver
How to install memory card in garmin nubi 50lm gps
  • 10 Answers
SOURCE: Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Posted on Oct 04, 2007
  • 174 Answers
SOURCE: Garmin Streetpilot i3 GPS cannot load map to memory card
null
Posted on Jan 28, 2008
  • 174 Answers
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Posted on Jan 30, 2008
haveing a hard time trying to download any updates. I dont have the disk eather for my unit. I have the streetpiolt 2720
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: can i put a 512 mb card in a garmin 176 c ?
i have a 1 gig 182c works fine
Posted on May 07, 2009
It won't pick up the satellite signal so its stuck at it last place searching for a satellite feed.
Should not take more than that unless you have installed a new set of maps in a new location. Call Garmin to confirm. Try installing latest firmware for unit to see if that resolves the issue.
If that does not do the trick then maybe...................................
Oct 15, 2015 | Garmin Nuvi 50Lm - Gps Receiver
My garmin nuvi 50lm keeps saying no detailed maps
If you have a sim card installed make sure it is fully in. Also this may occur when yhe battery is extremely low and trying to charge during use. Had this happen just last week and after about an hour of charging it started working correctly. Not sure if it was the sim card, low battery or unit placement as I also moved the unit up into the window instead of sitting on top of motor compartment in my van.
Sep 26, 2014 | Garmin Nuvi50lm Lower 48 Gps Device
Garmin troubleshooting
Buy an 8GB micro SD card and install in your 50LM, then download the maps to the micro SD card. Your internal storage is not large enough for all the maps with the updates. Hope this helps.
Aug 01, 2014 | Garmin Nuvi 50Lm - Gps Receiver
Have Nuvi 50lm I want truck software so i can see low bridges
You must buy new device which support truck features.If you try install other software which is not supported on your Garmin,you can brick your unit.
Nov 26, 2013 | Garmin Nuvi 50Lm - Gps Receiver
When I select my Trip Log for a restore, there is no way that the trace lines can be erased on my garmin Muvi 50LM. I need to delete these lines without restoring everything from the beginning.
Just turn the lines off. At the main menu, press the settings/wrench button, then the map button and then press the button under the trip log text. Set it from SHOW to HIDE.
Sep 21, 2013 | Garmin Nuvi 50Lm - Gps Receiver
Nuvi 50lm no sound
The only other possibility would be a blown speaker. It does happen. More info here:
http://www.sharc.net/gps_audio_repair.htm
Apr 07, 2013 | Garmin Nuvi 50Lm - Gps Receiver
Nuvi 50lm can't find maps
There are two different things to try.
1. Do a hard reset, that should restore the software and maps to their base condition.
2. Run Garmin Express and apply any updates it shows.
http://www.resettoo.com/hard-reset-garmin-nuvi-50lm
Aug 22, 2017 | Garmin Nuvi 50Lm - Gps Receiver
Garmin gps 50lm stuck on home screen when powering on
I had the same problem and the solution is mindbogglingly stupid and impossible to figure out! It took hours of research...
garmin 50LM gps
Aug 31, 2012 | GPS
Garmin Nuvi 50Lm - Gps Receiver Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
