Question about Motorola Mobility Mbp35l Digital Video Baby Monitor With 3.5" Lc
My antenna broke off
The antenna came off the back and the wires broke off with it.
  • Official Brand Answer
  • 1,623 Answers
Contact Looking For Help for help.
Mark
Motorola Support
Posted on Jan 27, 2015
Tundra antenna removal
You will have to un-install the entire antenna system from the inside.
remove the panel carefully adjacent to the antenna system
undo the bolts and clamps that hold the system in place
you can try and install the new antenna piece without disconnecting the transfer wire that goes back to the radio. But usually you will need to get and install a new system.
just to keep you going in the mean time you could just use a old wire coat hanger "classic" just bend the hook straight and shove it in, you have your sounds back.
all the best
Feb 02, 2014 | 2010 Toyota Tundra CrewMax
Need to know where antenna card is located on my p25 toshiba laptop
The Wireless Module is located on the Bottom of the laptop,
http://www.irisvista.com/tech/laptops/ToshibaP25/disassembly/big/Toshiba_SatelliteP25_03.jpg
The top card to the left. (With the red arrow)
White Wireless Antenna wire, and a Black Wireless Antenna wire.
You can see which terminal the White wire connects to. Leaves the other terminal for the Black wire.
Beginning page of pictorial disassembly guide, (Page 1),
http://www.irisvista.com/tech/laptops/ToshibaP25/SatelliteP25_1.htm
Page1::Page2::Page3::Find another model, is in White, and on the Top of each page, and Bottom of each page.
The Wireless Antenna wires attach to the Wireless Module,
http://www.ebay.com/itm/WIFI-WIRELESS-PA3299U-1MPC-Card-for-17-Laptop-Toshiba-Satellite-P25-/170900245815?pt=LH_DefaultDomain_0&hash=item27ca72cd37
Looks to me the White wire to MAIN, and the Black wire to AUX.
The Wireless Antenna wires then thread up through a cavity (Hole), in the laptop body, and go through/by the Right Hinge.
From there they go into the Display Assembly, and connect to the Wireless Antenna,
http://www.irisvista.com/tech/laptops/ToshibaP25/satP25_LCD.htm
http://www.ebay.com/itm/Toshiba-P25-Satellite-Laptop-WiFi-ANTENNA-K000006070-/220547282983
Scroll down, read the description.
The Wireless Antenna wires route through CHANNELS, and LATCHES.
The Wireless Antenna wires MUST go back in the SAME routing they were originally.
Failure to do will cause the laptop to not go back together correctly, and can cause damage to the Wireless Antenna Cable. (Wires)
[Pinched/Broken]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 06, 2013 | Toshiba Satellite P25-S607 Notebook
2002 Chrysler Town & Country antenna installation
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
Jun 04, 2012 | 2002 Chrysler Town & Country
My antenna broke off when I went through a car wash, how do I replace it?
if part is still left where antenna was take a pair of pliers and turn counterclockwise(left) to remove old piece left. go to most auto parts stores and they should have an original equipment replacement antenna
Jan 14, 2011 | 2004 Mercury Sable
I was removing the antenna, and it broke off. Do
Depending on if your car has a power antenna or not, you may have to replace the whole unit.
The good news is, no, you usually don't have to replace the wires on most GM vehicles. Open your trunk, remove the insulating carpet from the side of the trunk where your antenna is located , to expose the power antenna unit.
This is a stock photo of what the power antenna unit and kit looks likes.
Unplug the electrical connector from the antenna . Unscrew the plastic ring on the outside of the car, where the antenna rest on the body of the vehicle. Pull the antenna unit inside through the hole to remove.
You can usually get a new one for about $89 bucks at Autozone.
Installation is the reverse of remove. Make sure the ignition key is completely off when performing the replacement. Follow all installation instruction on the package. Improper installation could cause rain to leak in your antenna during bad weather and not be water tight.
May 25, 2010 | 1995 Chevrolet Camaro
Antenna bolt broke, how to fix antenna base.
This is probably way more information than you need, but here goes. I just had the same problem with my dads 2001 YUKON and wanted to put the stock wire back. It was not easy, but it can be done.
Remove the glove box, and plastic side panel on the dash
As you are looking through the removed area, there is a silver computer there, remove the bracket and move this computer.
Behind the computer there will be the plug in for the antenna. One side goes to the radio, the other to the fender.
Unplug the cable, and tape/fasten a length of wire to it so that when you pull it out, you have a guide to get the new wire back through the firewall.
Remove the old ant. and then take the guide wire and fasten to the new cable. Pull this guide wire through while someone else is feeding from the fender area.
Replug it, and reinstall the computer and glove box door.
Also, be aware and make sure that the new cable with stud matches the ant. mast. GM changed the size of the stud (for unknown reasons)and you may need to get a new matching mast. I could not use my old one
Dec 01, 2009 | 2001 Chevrolet Silverado 1500
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Antenna
Some wire less routers allow for a replacement or upgraded antenna (I know most Linksys routers do) which you can get at an electronics store.
Check on Netgear.com or look in the manual to see if your router is capable of that.
Jun 13, 2008 | NetGear WGT624 Wireless Router
Antenna broke and I replaced it
If your not sure what to do at this point you probably should stop right here, however if your bold enough to try this, remove the back cover, I believe there are 6 (six) screws in total, there is also a small metal contact that touches the main circuit board on the back side, that also connects to the antenna, most often a springy piece of gold plated metal attached to a solid threaded nut, where the antenna is attached that fits snugly into the back cover of the phone when the cover is installed the nut is secured and won't fall out. This contact could be on the nut or on the main board if you bent it out a bit to make better contact, you will most likely fix your phone. Cheers!
Mar 03, 2008 | Cell Phones
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
Motorola Mobility Mbp35l Digital Video Baby Monitor With 3.5" Lc Logo
71 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
