Question about IBM Wheelwriter 30 Typewriter
Ribbon won't advance on IBM Wheelwriter 3
The small gear that the ribbon cartridge attaches to does not advance the ribbon,
  • IBM Master
  • 3,594 Answers
Try some WD40 on the feed motor bearings top and bottom and the gear train it drives.
DickyO
Posted on Jun 19, 2009
Ribbon advance gear is stuck
On the R. hand side of the ribbon deck is the motor for ribbon feed, put som WD40 on the upper and lower bearings they do gum up and freeze the motor.
DickyO
Apr 09, 2014 | IBM Wheelwriter 3 Electric Typewriter Type...
Install lift off tape cartridge
Remove the ribbon by pushing the blue lever to the right and front of the ribbon. The correction tape cartridge is attached to the bottom
of the Printing ribbon. Depress the center of Printing ribbon to release the correction ribbon. Snap on a new one.
Nov 04, 2013 | IBM Personal Wheelwriter 2
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
First try a little WD40 on the ribbon motor bearings top and bottom, ckeck the plug that is plugged into it. The motor is under the R. corner of the ribbon deck towards the front of T/W.
DickyO
Jul 17, 2010 | IBM Wheelwriter 30 Typewriter
My ribbon broke, I don' t know how to fix it.
The ribbon has 2 little (feet) on the rear of the cartridge they hook into the ribbon deck and it just rocks into place. You can get a picture and instructions @ lexmark .com klick your way to publications. Be sure to advance the ribbon by hand a foot or so to be sure it isn't sticking to itself.
DickyO
Sep 29, 2009 | Lexmark Wheelwriter 3 Typewriter
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter III
gotta clean the wheel off with old ink sometimes this can be a problem but the ribbon might not be seated properly
May 07, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM Easystrike Cartridges
The ribbon cartridges can be pried apart they are pressed together, getting it apart is easier than putting back together.
Next time you have to install a ribbon advance it by hand for a foot or so as old ribbons tend to stick to themselves.
Hope this helps
DickyO
Feb 08, 2008 | Lexmark Wheelwriter 3 Typewriter
IBM quietwriter 7 - autocorrect problem
Do you have a lift off tap snapped onto the bottom of the ribbon
Nov 07, 2007 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
247 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
