Question about Car Audio & Video
I have a new xo vision gx1559 with red power light and dome lights on but it wont turn on is there more than one fuse on unit
SOURCE: No light fuse is good unit (1) want power up and unit (2) red light but want do nothing both are connected to AC power source
The CH DVD300 is notorious for power supply problem. If this the case, you can send the power supply to be repaired for around $15.00 to:
Wired Communications
31211 N. 77th Way
Scottsdale, AZ, 85262
Tel. 480-209-1700
Contact them before sending anything.
Francis
Posted on Oct 12, 2007
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
  • 216 Answers
SOURCE: XO Vision GX 1236
With solder.
atdlee@netzero.com
Posted on Mar 08, 2008
  • 3 Answers
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Posted on Apr 06, 2009
vwmike2001
  • 74 Answers
SOURCE: clock, and dome light (2004 aveo)
If the fuse blows when you start the car their is a bare wire somewhere in the wiring system that is grounding out when power goes through the system. Thier is a possibility of it being something else that is on the same fuse. You will have to trace the wires to find out what and where it is exposed. Your switches should be tested also. The switch that turns the light on manually and the one located in the door jam itself that turns the light on when opening the door. You should bring your car to a mechanic who is qualified in electrical dianosis. I hope this helped you out. good luck..... It would be appreciatted if you could rate my answer. tThanks....MIKE-
Posted on Aug 25, 2009
Restart button
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Nov 18, 2013 | XO Vision Tablets & eReaders
Amp wont turn on
Your stereo has 2 blue or 1 will b blue with white. One will supply power to a power antenna which will only have power on radio mode not cd do check wires with test light coming out of your head unit for the remote turn on and not power antenna
Jul 29, 2012 | XO Vision XOD1735 Car DVD Player
At first the screen went dim but you could faintly the picture no sound through the main speakers but wireless headphones still worked then everything went dead the disk would not turn. the red light...
looks like you have a cold solder/loose board on the power supply section of the unit.try resoldering first and post a comment how it goes..let me know ..thank you..
Feb 17, 2011 | XO Vision Televison & Video
Where does the lamp in wire go
I believe this is where the fade for the dome lights would connect. This will allow the screen to dim when the rest of the lights are faded?
Dec 26, 2010 | XO Vision XOD1750 Car Video Player
Car has been in bodyshop for new paint not from accident, now player will not power up, fuses are good and power light glows red any segestions
Find out if they did any welding on your vehicle. Sometimes the welder causes a disrupiton in the system if the batttery isnt disconnected
May 26, 2010 | XO Vision XOD1911 Car DVD Player
Whats the pink wire for? it says "lamp in"
it hooks to the panel lights in your car so you can adjust the brightness in the unit.  Just hook it to your switched on power wire.
Apr 04, 2009 | XO Vision XOD1735 Car DVD Player
DVD won't play and screen won't turn on
Do you have 12VDC going into player?
Do those dome lights can be turned on & off?
atdlee@netzero.com
Feb 02, 2008 | XO Vision GX1042 10.4 in. Car Monitor
XO Vision XO-141FM 14.1 in. Car Monitor
Check voltage going into player.
It should be 12VDC.
atdlee@netzero.com
Feb 02, 2008 | XO Vision XO-141FM 14.1 in. Car Monitor
E- brake bypass
Thanks for everyone's help. The bcar screen actually is the backup camera screen which is activated by the orange wire and when I turned on the lights, it got activated. I disconnected the orange wire and everything is fine. When I get a backup camera I'll connect that wire to the backup lights so that it will come on whenever I put the car in reverse. You are right that their manual is not very clear at all. I called their tech support and they couldn't help me trouble shoot the problem either. The unit is functioning perfect now but my next beef is that you can't change the XO vison default screen when a cd is playing. It would have been nice if you can scroll some jpeg shots of anything else besides looking at the xovision logo. I guess I can't have it all for $340 so, I'll stop whinning.
Jan 26, 2008 | XO Vision XO-1400 Car DVD Player
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
