Question about BenQ Televison & Video
How to open up the remote BenQ dv3750
We can here loose parts inside rattling around but we removed screws on bottom and it wont come apart..how can we get it apart? ty
gwshaw71
  • 83 Answers
SOURCE: bottom screw on handle loose
open the door and you will have to peel and pry apart door.It is abot a 1-2" frame around inside door.that peels off it just snaps in.
Posted on Nov 25, 2007
SOURCE: Bass Flow Tube
Carefully pry off the gray metal mesh covering the speaker. Don't pry on the plastic ring - you have to remove the metal mesh from the plastic. Remove the six screws holding the speaker in place, and remove the speaker. Finally, re-glue the tube into the port. Wait for the glue to cure before turning the speakers on again.
Posted on May 19, 2009
SOURCE: removing inside door handle
i have a hyundai accent 2001 and i need to find fm stations manually.
Posted on Mar 06, 2010
jennasa
  • 5 Answers
SOURCE: g9 won't start screw rattle inside sounds
This sounds like the typical G9 no power loose screw scenario. This is really common on the G7 and the G9 model. The place for service on these is www.camerasandparts.com They only service the Canon Powershots and they are excellent for help with these. The nice thing with them is they do the fix to those internal screws so it doesn't re-occur on the camera. If you need help with a Powershot problem, they're the place. They have your Canon G9 no power service on their site. All the best looking after it, there great if you need help with one of these.
Posted on Jun 25, 2011
reyjoshua07
  • 1157 Answers
SOURCE: My Bose rc28t1-27 remote feels
Hi mjlfield,
That rattling sound is the antenna core broken loose from the board. It needs to be re soldered back on. The case is snapped together very hard and takes a lot of squeezing to get it apart. You will also need a soldering iron to solder the antenna back on.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 17, 2011
How to take apart Sony NSGMR1 remote control
You may have the diode loose or a crystal some use on the board.
look aside from back in bottom of battery compartment for more screws.
Many of the remotes even with screws are snapped together--look at the seam in the side around the remote--start at the bottom on one side and probe with a small screwdriver--insert into the seam and slide to try to free the first locking tab--pull on it(the case halves) and slide the driver slowly along the seam to unsnap all the tabs.
You may cause some slight chips or scratches in the process and that is normal--as you get the tabs released pull up on cover until the unit comes open.
Inside there are generally the two cover sides, the board, and the rubber like mat with all the buttons.
Take your time as only other choice is to buy a new remote which I suspect will be expensive.
Let me know if get it apart or have problems doing this.
Jun 02, 2012 | Sony Nsgmr1 Remote Control
How do I open toshiba ct-90287 case to dry buttons
I guess this is a remote control.
Remove the batteries and look around including inside the battery cover for any small screws.
Remove all screws - Even If there isn't any screws.
Next>
You need a fairly wide but thin flat bladed screwdriver to split the case. Place the blade of the screwdriver between the two casings of the remote control and gently twist the blade and the case will begin to split apart. work it loose - but don't foce it apart. Apply even pressure around the remote control with the blade of the screwdriver.
Once you have seperated the two halves - clean the rubber buttons with either Meths or Isopropyl Alcohol and also clean the circuit board with the same where the buttons make contact with the circuit board. Then reassemble. Your control should then be ok!
Jun 22, 2011 | Televison & Video
My niece squeezed an object into my Benq DLP W100 projector and now it is manfunctioning. I think it would be a simple solution if I could only open the unit. How to do that however. I removed all the...
I got the same projector and have had to take it apart a few times, they are not to hard to open
There are 5 (not inc the projector cover screw) screws to remove from the bottom of the projector (A long neck philps screw driver will be needed). Once these are removed The top will be loose apart from catching midle of the front and at the back, This is down to the top being clipped in the middle.
Remove the grey panel round the connectors, one sreew and the 2 plug fixing nuts around the DVI Port. Once these are removed pull the panel away from the projector, pulling from the midle of the panel as its cliped to the side. Once remove lift the top of the projector roateing it around the front
Hope this helps
May 09, 2010 | BenQ W100 DLP Projector
I have a 37" BENQ LCD(model # DV3750), I was watching the tv and it poped then would not turn on. I called a tech and they told me it mabe the power supply, so i took the back off the tv and looked at the...
I have the exact same part burned at the bottom. I just used a long nose plier and bend the bottom so it touches the print board circuit. It works. I guess I could also use a soldering iron to fix it. But will see if this temp solution works or not.
Feb 27, 2010 | BenQ DV3750 Television
Internal cracked screen on benq dv3750
you cant falls under cusatomer abuse so you gotta pay for a new panel or buy a new one... btw, panels cost more than what yopu originally paid for the uin it
Jul 18, 2009 | BenQ Televison & Video
Receiver rattles. Like something loose inside.
The rattle is probably a weight. On purpose, they put a piece of metal in the handle part of the handset to give it more weight.
If there isn't a secret screw under anything in the handle, it's probably glued or clipped at each end. Those are the worst kind.
Sometimes a slight pressure at the break near the top of the receiver will be enough to seperate it to get a knife in the opening to pry it apart.
When you get the 1/3 part of it up, look to see if there isn't something else holding it. It may lead you to the tab or screw that does.
Before you destroy the handset, look under the receiver part on the inside. With any luck, there will be a part number. You'll need that when you order a new handset :-)
Carl
Mar 22, 2009 | BellSouth Lands Phones
How do i open the mbox 2 pro?
There are five shiny screws and one black one located behind the plastic front label (the part that has the markings for the input levels and switches), plus three behind the serial number label, inside the handle part you open with the allen key. This removes the front panel, then, there are about twelve screws around the plastic casing, attaching the casing to the inner metal encasing.
There are three screws behind the foam strip on the metal casing, which attach a heavy duty metal strip to the inner casing... the rest are obvious.
This is how to deconstruct the casing in the event that something is rattling inside.
Keep in mind, if you still have a warranty on your MBOX 2, you won't anymore once you deconstruct it. So I don't advise it unless your device is well past warranty.
Though, if something is indeed rattling inside, I'm sure that's a breach of warranty conditions anyway.
You had best check on that first, but you might end up taking her apart anyway.
Jan 05, 2009 | Digidesign Mbox 2 Barebone
Need to Buy a main system board/controler board for BenQ DV3750
Really Did not find a solution because we already know the problem. i.e the mani/digital board. BenQ will not sell us the part. We are still looking for a supplier.
NEVER NEVER Buy BenQ
Nov 15, 2008 | BenQ DV3750 Television
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Televison & Video Logo
15 people viewed this question
Top BenQ Televison & Video Experts
Electro Med Services...
Are you a BenQ Televison and Video Expert? Answer questions, earn points and help others
