Question about Husqvarna 967 00 36-01 - RZ5426 54" 26HP Kohler Zero Turn Lawn Mower
How much oil does hold - Husqvarna 967 00 36-01 - RZ5426 54" 26HP Kohler Zero Turn Lawn Mower
Ford explorer trac 2007 change the oil and filter and now have a wrench light on ,how resolve the problem
Sounds like you need to reset your Oil life/ maintenance reminder light. (also, double check your oil level)
To reset Oil life on a standard dash stlye:
1. pres and release the TRIP/RESET button until the message center displays SETUP MENU HOLD RESET
2. Press and hold the TRIP/RESET button for 2 seconds until the message center displays RESET FOR SYS CHECK
3. press and hold the TRIP/RESET button for 2 seconds until the message center displays OIL LIFE xx% RESET IF NEW
4. Press and release the TRIP/RESET button until the message center displays HOLD RESET IF NEW OIL
5. Press and hold TRIP/RESET button for 2 seconds and release to reset oil life to 100%
6. Message center will briefly display OIL CHANGE SET TO 100%
With a message center cluster the procedure is as follows:
1. press and release SETUP button until message center displays PRESS RESET TO BEGIN SYSTEM CHECK
2. Press and release RESET button until the message center displays HOLD RESET IF NEW OIL
3. Press and hold RESET button for 2 seconds and release to reset the oil life to 100%
4. The message center displays SETUP MENU HOLD RESET
Hope this is what you need/ are looking for. Goodluck & let me know how it goes, or if you have a different problem.
Nov 03, 2013 | 2006 Ford Explorer
How do you reset the oil change required after oil change on a 2007 ford explorer sport trac limited?
Depending on your cluster its one of these...
Message Center Configuration
Oil Life Reset - Message Center Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days
  1. Press and release the SETUP button until the message center displays PRESS RESET TO BEGIN SYSTEM CHECK.
  2. Press and release the RESET button until the message center displays HOLD RESET IF NEW OIL.
  3. Press and hold the RESET button for 2 seconds and release to reset the oil life to 100%.
  4. The message center displays SETUP MENU HOLD RESET.
Oil Life Reset - Base Instrument Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days.
  1. Place the ignition in the RUN position with the engine off (KOEO).
  2. Press and release the TRIP/RESET button until SETUP MENU HOLD RESET is displayed.
  3. Press and hold the TRIP/RESET button until SYSTEM CHECK is displayed.
  4. Release the TRIP/RESET button.
  5. Press and release the TRIP/RESET button to scroll through the system check menu items until HOLD RESET IF NEW OIL is displayed.
  6. Press and hold the TRIP/RESET button until OIL LIFE SET TO 100% is displayed.
  7. Release the TRIP/RESET button. The oil life is now reset.
Oil Life Start Value - Message Center Cluster
NOTE: The oil life start value is used to reset the oil life value back to the maximum of approximately 8,000 km (5,000 miles) if the value was previously changed or to lower the value from the maximum (8,000 km
To reset the oil monitoring system to 100% after each oil change [approximately 5,000 miles (8,000 km) or 180 days] perform the following:
  1. Enter SYSTEM CHECK to display "OIL XXX% OIL LIFE OK".
  2. Press RESET control to display "HOLD RESET IF NEW OIL".
  3. Press and hold RESET control for more than 2 seconds. Oil life is set to 100% and "OIL CHANGE SET TO 100%" is displayed
Mar 06, 2011 | 2007 Ford Explorer Sport Trac
Turn of sign ''oil change required''
have you changed your oil? If its new then just reset the computer/ diagnostic screen between your RPM and Speed. Press the screen button until it reads "setup menu, Hold reset" now hold the button until the screen changes again.
press the button until screen reads "system check, hold reset"
press and hold the button. It will start a basic system check,
First check is for oil, it will read the percent of "good oil left" and say "if new, press and hold reset"
thus press and hold reset, and the computer will reset your oil life to 100%.
Oct 16, 2010 | 2006 Ford Explorer
How many quarts of motor oil does it take
4.3 ENGINE HOLDS 4.5 QUARTS WITH NEW OIL FILTER 4.8 - 5.3 -6.0 -ENGINES HOLDS 6.0 QUARTS WITH NEW OIL FILTER. 6.6 DIESEL ENGINE HOLDS 10 QUARTS OF OIL WITH NEW OIL FILTER.
Sep 01, 2010 | 2005 Chevrolet Silverado 2500HD 2WD
Oil change signal still on after oil changed
[approximately 8 000 km (5 000 miles) or 180 days] perform the
following:
1. Press the SETUP control to
access the System Check function
control to display “OIL LIFE XX%
HOLD RESET NEW”.
control for 2 seconds to display “IF
NEW OIL HOLD RESET”.
4. Press and hold the RESET
control to display “OIL LIFE SET
TO 100%”. Your oil life is now reset.
This procedure is on pages 69-70 of your owners manual, this is copied and pasted from that manual
Feb 18, 2010 | 2003 Ford Windstar
How do you reset the change oil message on a 2007
Ford Explorer, Mercury Mountaineer, 2002-07
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the SET UP control to access the System Check mode. Press and release the RESET button to display “OIL LIFE % HOLD RESET NEW” is displayed. Press and hold the RESET button for 2 seconds until “IF NEW OIL HOLD RESET” is displayed. Press and hold RESET button until “OIL LIFE SET TO 100%” is displayed.
Ford Five Hundred, Freestyle, Mercury Montego 2005-06 Tap the ODO/TRIP button to toggle the display between the odometer and trip odometer. Tap on the ODOiTRIP button again to toggle the display between the trip odometer and OIL LIFE % display. Press and hold the ODO/IRIP button for 2 seconds or more to display OIL LIFE 100%. Your oil life in now reset.
Jan 06, 2010 | 2003 Mercury Mountaineer
Changed the oil in a 2006 mountaineer but the change oil warning won't go off
You need to reset the oil light using the reset button on the steering wheel. Press the set up button to access the system check mode. press and release the reset button until the display reads "oil life hold reset new". PRess and hold the reset button for two (2) seconds until "if new oil hold reset" is displayed. Press and hold the reset button until "oil life set to 100" is displayed.
Dec 05, 2009 | 2006 Mercury Mountaineer
Changed oil and message center still says oil change required (2002 mercury mountaineer)
Ford Explorer, Mercury Mountaineer, 2002-06
Nov 03, 2009 | 2002 Mercury Mountaineer
Oil reset
Courtesy of http://synthetic-direct.ca
Jul 21, 2009 | 2006 Ford Explorer
How do you turn off the oil change message in the 2002 ford explorer after the oil has been changed?
FROM YOUR OWNERS MANUAL:
[approximately 8,000 km (5,000 miles) or 180 days] perform the
following:
access the System Check function.
HOLD RESET NEW”.
control to display OIL LIFE SET TO
100%. Your oil life is now reset.
To reset the oil monitoring system to your personalized oil life %:
HOLD RESET NEW”.
Apr 15, 2009 | 2002 Ford Explorer
Husqvarna 967 00 36-01 - RZ5426 54" 26HP Kohler Zero Turn Lawn Mower Logo
32 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
