Question about Gaggia Evolution Espresso Machine
Pump doesn't work any longer - Gaggia Evolution Espresso Machine
I have ford bantam 1.6i rocam 2006 model. It Doesn't start, It doesn't pump the petrol, the is no power to fuel pump
Refer to your manual there is a switch that deactivated the fuel pump in case of accident, there is a switch by the pasangers feet that if in the up position is activated to stop the fuel...
Aug 28, 2012 | 2006 Ford Bantam 1.6i
Machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump, or broken belt replace+lid swtich defective
It pumps, but doesn't spin
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
It spins only with the lid closed
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
White spot on my laptop screen
Increase color depth for strange colors on your display.
If that doesn't work you probably have dead spots on your screen that no longer work. This means that your LCD assembly is no longer functioning and you will need to replace it.
Apr 04, 2012 | LG Computers & Internet
Alero Stalling and Problems starting.
Check your fuel pressure sounds like to me the fuel pump is weak or worn out.
Dec 12, 2011 | 2001 Oldsmobile Alero
Have to pump gas pedal and hold key to start, 30-50 seconds. when i get it started it and let off the gas it will sputter and sometimes stall. especially when in gear.it also seems to be overheating.
check the fuel pump, when you turn the key to the on position, the pump should start for a couple of seconds, it sounds to me like its not keeping the fuel line pressured any longer, which is why your having starting problems, when you turn the key to on, Listen for the pump to start, you will hear it hum ever so slightly,, after a couple of seconds it should stop, if it doesn't,, its losing the pressure needed, you can have them checked , its not very expensive to get them checked, having to pump the pedal,, doesn't help with this problem,, and the over heating is more than likely associated with it too,, if its not firing correctly, it will tend to over heat at times
Oct 07, 2011 | 1999 Mazda 626
Need an exploded diaghram of power steering pump to replace gasketes and orings
I really doubt that you can get parts for your car/truck power steering unit. Now day it R and R. Maybe on some old model maybe.
Remove and Replace. I can almost guarantee that it cheaper to get a rebuilt power steering pump and trying to fine parts then brake down the power steering pump and then reassemble it, and hope it works. If you purchases a rebuild pump and it doesn't work. Take it back and the auto retail store will just replace it. Try do that to a pump that you or your friends rebuild and it doesn't work. It easier to replace it. Sorry.
Back in the 50's we rebuild everything, pumps, water pumps, generator including rewinding the commentator with new connector. rebuild brake shoes. GB you.... stewbison
Aug 21, 2011 | Subaru GL Cars & Trucks
I have #10708 S(or 5) 04P03325 pump dehumidifier. The pump doesn't work. We actually had this happen the 2nd yr we had it and brought to repair shop and it worked 1 yr and again not working. I...
IT SHOULD BE THE REPEAT OF THE SAME PROBLEM. WHY NOT TRY AN AUTHORISED SERVICE CENTER THIS TIME. YOU WILL ALSO GET ADVICE IF ANYTHING YOU ARE DOING IS CAUSING THIS TO HAPPEN.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | DeLonghi Kitchen Ranges
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
My 2000 silverado 4x4 5.3 auto has lost power
When was the last time you changed plugs, wires, and cap/rotor? Also check the fuel filter.
Dec 22, 2009 | 2000 Chevrolet Silverado
Gaggia Evolution Espresso Machine Logo
53 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
