Question about Romertopf Clay Baker 14 - 17.5 lbs Home
Romertopf soak 2 hours - Romertopf Clay Baker 14 - 17.5 lbs Home
How do i soak in my machine
If the machine has a soak button on the panel, when pushed, it will fill and wash and then it will stop for around 2 hours. Then it will continue the rest of the cycle. If no soak button is on your model then it won't do any of that.
Oct 20, 2014 | Fisher and Paykel Fisher & Paykel Washer
How can I soak clothes overnight?
1. Open the door to force a soak.
2. Unplug the unit if you're able.
3. Shut off the circuit breaker.
Sep 02, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Dishwasher does not clean tea stains from teacups- we have tried a variety of soaps and have used sani-clean. Machine is only one month old- new fully integrated model.
Method #1
  • Wet a cloth then rub the inside of the mug with baking soda. If the stains are stubborn, soak overnight in hot water and baking soda.
Method #2
  • Soak the mug in bleach OR vinegar for several hours or overnight.
Method #3
  • Fill mug with boiling water, add two spoonfuls of dishwasher detergent then soak overnight.
Method #4
  • Try a paste of corn starch and vinegar, apply and let sit for a few minutes then scrub away.
Method #5
  • Drop two denture tablets in the mug, pour hot water over top then soak overnight.
After soaking mugs and removing the stains, rinse and wash very well before using-especially when using the bleach method.
May 06, 2011 | Samsung Dishwashers
I got the xtra wide propane smoker and when I seasoned it before using it my wood chips caught fire , i had soaked them for 1/2 hour . When i went to smoke some fish I soaked my wood chips for 5 hours and...
Hopefully, it's just a case of the burner turned to high. For most smoking applications is low and slow. By low, I mean no more than 200 to 250 degrees. And by slow (depending on what you're smoking primarily meats) 3 to 5 hours or more. Fish shouldn't take more than an hour and a half.
Check out the Masterbuilt website home page and you'll probably find the manual you need or you can contact them directly.
Feb 03, 2011 | Masterbuilt 20050106 Propane Smoker
Motorcycle will not exceed more than 20mph
You need to have your carburetors cleaned.
Its sounds like clogged jets.
I saw this several time.
Take carbs off bike, completely dissassemble all the jets from the bowls, take out diaphrams.
Soak everything except the float and the diaphram in a carburetor solution available at your local auto parts store.
Soak the carburetor bodies as well, even if the all don't fit turn them over every hour.
Let everything soak for at least 2 hours, rinse with water, and blow every port and hole in the carburetor bodies out thouroughly, then blow threw all the jets and make sure you can see through them and make sure you can see threw the little holes in the jets.
Once all clean, reassemble, and your bike will run like new.
NOTE: if removing the air fuel mixture screw, turn it in(counting the number of turn) until it stops, once it stops do not over turn it, STOP. now remove it and clean it and replace it. To replace it
turn it in until it STOPS. Then turn it clockwise back to the number turns you counted.
2 turns out is a standard setting to start at.
Dec 01, 2010 | 2005 Hyosung GT 650 S
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    Proud owner of a vertical propane smoker. Instruction book to assemble product in packaging, but no instructions on how to smoke. When using wood chips, after having soaked in water, do you add more...
    Oh boy another one who will soon have the bug. lol No, soak the chips and place them in the chip pan. As they burn down you can add more soaked chips if you like a more smokey flavor which I do. Maintain your temp at around 225. Pork butts will take 1 1/2 to 2 hours per pound.
    Now that have the bug do a search on smoker forums. There is a wealth of knowledge and help available on the subject.
    I hope this helps and good eating!
    Jun 13, 2010 | Masterbuilt 20050106 Propane Smoker
    How long does the soak programme last?
    For this machine the length of time of between 30 minutes and 2 hours can be programmed in 30 minute increments for the soak process.
    The machine is set ex works with a soak period of 2 hours.
    To programme in a different soak period see "Programmable functions - Soak" in your user manual. See Page 59.
    Oct 16, 2009 | Miele Novotronic Premier 500 Front Load...
    Nokia N95 keys wont work after being in my pocket in the rain
    remove the battery and, soak the phone in 90% isoprophyl alcohol (rubbing) using a spraybottle soak your phone completely let it sit for an hour (don't worry you will not harm it) then: using a hairdryer on low gently dry your phone replace the battery and, start it this should work if it doesn't then you must diassemble the phone and use the alcohol again inside it or, return the phone for repair the alcohol can be purchased at a drug store
    Apr 27, 2009 | Nokia N95 Cellular Phone
    Filter dries out
    2 things could be happening.
    #1. Your water has gotten harder in the last year and more deposits are getting caught on the filter. Try soaking it in water and vinegar for an hour. This should clean some of the deposits out and extend the life of your filters. Everytime it gets hard try soaking it.
    #2. Your machine is running out of water before you can refill. When this happens and the filters dry out, they aren't as good afterwords.
    I would advise trying to clean them with vinegar and water and making sure your machine is always full.
    Good Luck.
    Feb 20, 2008 | Kenmore 14410 Humidifier
    Home Logo
    361 people viewed this question
    Top Romertopf Clay Baker 14 - 17.5 lbs Home Experts
    john h
    Tom Chichester
    Are you a Romertopf Clay Baker 14 - 17.5 lbs Home Expert? Answer questions, earn points and help others
