Question about Adtran TSU ACE Modem
I have a mobily turbo bandluxe i need the password
Need to login give me the default password
Default login password
It would have been more comfortable, if you would have mention your router model name
so to give you the exact information about the password. Since to help you find default login and password for the router, please find the list of common routers from the link given below:
http://www.routerpasswords.com/
GuruAid.com
Mar 15, 2016 | Computers & Internet
How do I log in. reset password
Nearly all routers will have the password printed on the bottom. If it doesn't say password it may be just a series of letters and numbers with the login being admin as the default. Older routers use just admin for the login and password for the default password. Some it's admin and admin for both. To get to the login screen you would need to enter your gateway IP in a web browser, that is the same as your IP address except ends in a 1. Example http://192.168.1.1 will give you the default page on many home routers. Once logged in it is mostly self explanatory. With newer routers being much better. Without details on router brand and model or version of operating system you are using this is as close as it gets.
Dec 25, 2014 | Computers & Internet
Dont know my user name and pasword
If you didn't change it the default is leave the login blank and the password is admin
If you did change it then all you can do is reset it to factory defaults
Power off the router by pulling power cable. Press and hold the reset button which is located on the back next to the WAN port plug the power cable while continuing to hold the reset button for 5 seconds
deffault ip is 192.168.1.1 no login... password is admin
Jan 08, 2011 | D-Link Computers & Internet
Hya#was wondering could you tell me how 2 lock my wireless router, i run the pc and a laptop, but wud like it locked, thanx
you need to login the router in the address bar... the address depends on the make of the router, typically it's 192.168.1.1 for linksys. I would google Belkin (model#) password. and it will give your default username and password for your specific router. If somebody has already taken over your router just unplug it for a minute or press the reset button on the back. Resetting the power on it puts it back into default login, so now you want to change the administrator password after you login the router from the web address bar.
Dec 10, 2010 | Belkin (54G F5D7230UK4) Wireless Router
How can i find my wep key
your Wep Key is set up in your router, you have a netgear your netgears IP address default gateway is 192.168.2.1. Username: admin Password: password this should get you into your router look for security this will give you information to what your wep key is.
Jun 18, 2010 | NetGear DG834G Router
I changed the login/password when I installed my wrt160n router a couple of weeks ago. it won't accept my login/password now. How can I reset them??
Try the default password just in case the changes you made were not stored for some reason.
If this does not give you access, try resetting the router to factory default by pressing and holding the Reset Button on the rear of the router for approximately 10 seconds. Use a toothpick or similar as the button is small and recessed into the case to avoid accidental resetting. You will need to reconfigure all settings though.
The default way to get into the router is to type 192.168.1.1 into the browser address, the user name is left blank and the password is admin
user manual is available from HERE You need to select the correct version number from the drop down.
Jun 29, 2009 | Linksys WRT160N Wireless Router
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Apr 16, 2009 | Linksys RV042 VPN Router
What are the possible default passwords for the router?
The password would be blank/admin/smcadmin by default. Blank password implies that you need to click on login without giving any input. But, if you have set a password on your own and not able to recollect it, try resetting the router.
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Adtran TSU ACE Modem Logo
42 people viewed this question
Top Adtran Computers & Internet Experts
Gareth Tomlinson
Gareth Tomlinson
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
