Question about Samsung RFG297HDRS Stainless Steel
Samsung refrig cool pantry drawer stuck shut will not open
We can no longer open the cool pantry drawer in the Samsung Refrig RFG297HDRS Please help
SOURCE: Samsung Refrigator
how do i fill up the water and ice maker
Posted on May 09, 2008
  • 234 Answers
SOURCE: my refrig. wont cool
It sound like your defrost system has a problem and each time you unplug, the frost goes away and thefrig works ok until frost builds up again. Yoou need to see if it is defrost timer, defrost coil, or defrost thermostat. Now you need to be a good tech person to find each item and know how to test each part. I'll tell you the coil and stat are in the back of the freezer compartment, the timer is either under the frig(front) or in the frig compartment near the cold control. goodluck, macgivor
Posted on Dec 27, 2009
  • 67 Answers
SOURCE: The temperature reading on the outside door panel flucuates
Could be a fan problem, open the door and hold the door switch in, the fan should start and you should be able to feel air coming out the vents (air flow is not very strong as it comes out many vents so you will feel a cold breeze rather than a strong air flow if it is normal. Also check if you can see any ice nuild up in the back of the freezer as it may be a defrost problem and the air can't flow due to the ice build up, if this the case it will need to be looked at.
Posted on Apr 18, 2010
  • 7 Answers
SOURCE: RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Posted on Jul 11, 2010
ginko
  • 19396 Answers
SOURCE: I have a Samsung RFG297AABP
Hi.
If the leak is not too big, then water comes from condensation. Water condensing inside the fridge is supposed to be conveyed toward the drain hole inside the fridge. From there the water should normally go to the drain try located in the compressor assembly.
What usually happens is that the drain hole gets clogged with frozen water, and the condensed water ends at the bottom of the fridge. The problem is fixed defrosting the fridge. In some sporadic case it is necessary to remove drain hole blockage using a thin and flexible drain rod.
Do a complete defrost, that should fix the problem.
Here all parts and diagrams for this fridge.
Regards.
Ginko.
Posted on Apr 15, 2011
Can't get rf266abpn cool select pantry drawer back in
There may be guide rails on the underside of the shelf above.
Apr 25, 2016 | Refrigerators
Samsung refrigerator rfg297aarf cannot put cool select pantry drawer back?
I don't remember exactly how that one works but try these two options...
1) tip the front of the drawer up more than 45 degrees and connect the rear to the tracks, then lower the front until the drawer catches on the rails - it will push in and slide out correctly.
2) look under the shelf where the drawer attaches, you may have to get down on your knees and really look in. Pull all moving clips that are in the drawer tracks forward (they may have been moved back while cleaning). Then connect the drawer to the slider clips (it should be obvious how they clip in if you have the slider clips).
Hope one of those was right for your unit.
Cheers
Jun 06, 2015 | Samsung Refrigerators
Cool Select Pantry, to relocate per manual instructions, doesn't slide all the way in.
Cool select Pantry
To remove the pantry - Pull the pantry out to full extension. Tilt up the front side of pantry and pull straight out.
To relocate the pantry - Push the rails to the back of the Refrigerator. Place the drawer onto the rails and slide the pantry back until it is in place.
before install they ask to push the rails to the back of the refrigerator
should be no problem
Jul 29, 2014 | Samsung RFG297AARS Bottom Freezer French...
Water leak samsung rm255barb
sorry,don't have same refrig nor that kind of problem so can't help you!
May 29, 2014 | Samsung RM255LASH Side by Side...
My RF263AEWP Samsung is 3 weeks old. The pantry cool drawer sticks as I pull it out and sticks as I push it in. The lid does not close completely on one side.
Mine does the same thing. The repair man brought a new drawer and it does the same thing. Look underneath and you will probably see that the wheels don't fit correctly on the tracks. Samsung is saying this is how it's designed. :(
Sep 20, 2010 | Samsung RF265AA Bottom Freezer French Door...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Samsung RFG297HDRS Stainless Steel Logo
361 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
