Question about Bushnell Neo Plus GPS Watch
Watch will not charge
The charging screen does not come on. New watch, I charged once with no problem.
My Citizen echo drive does not hold a charge.It is 9-Months Old .
Place the watch in direct sunlight of sunrise or sunset for a few weeks and also bright light but not hot light. Wear as usual in direct sunlight as the occasion allows. Once these kind of batteries are discharged, they need quite some time to recharge. Wearing a new solar watch most of the time indoors with bright light only, is normally not enough but once the battery reaches full charge, the extra bright light conditions can be relaxed.
Sep 25, 2017 | Citizen Watches
How do I charge my watch?
To charge your Apple Watch: Plug the Apple Magnetic Charging Cable, Apple Watch Magnetic Charging Case, or Apple Watch Magnetic Charging Dock into its USB power adapter. Plug the adapter into a power outlet. You can also plug the charging cable into a USB port.13 Sep 2016
Check your battery and charge your Apple Watch - Apple Support
https://support.apple.com/en-gb/HT204608
Dec 09, 2016 | Watches
I was given a skyhawk eco drive watch from my late fatherinlaw,its brand new but it has been in its case(box)in dark for a long time and doesn't work...how do I get it going???
An Eco drive citizen is powered by the sun. You should take the watch out in the sunlight or put under a lamp to charge it for at least 12 hours. Once it is running you need to wear it to keep it running, you should be able to take it off at night and it will continue to run once it is fully charged. if it does not hold a charge over night after being fully exposed to light for 24-48 hours you may need to send it to Citizen for service on the capacitor. thank you!
Aug 27, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Feb 20, 2011 | Seiko Kinetic watch
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
It wont charge
mcdevito75 here, Possibly the battery is worn out. An old battery will not hold a charge, Visit a small watch repair shop in yourarea for a new battery.
Jun 28, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I bought a new Mens Eco Drive WR200 SSB from Amazon. I understand that i needed to charge it in sunlight or lamp light which i have been doing for over a week now. In the sunlight, in front of a 40 watt...
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Citizen watch manuals. You will find explanations there. Rate me, please.
Feb 26, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
My MTG900 says, "Charge" on the screen...I got it last Christmas, does this mean I need a new battery?
CHARGE means you have to charge the watch. It depends on what type of movement you have. If it's solar powered, you need to leave your watch under the light to charge it. If it is battery powered - you haqve to buy the new battery and fit it. Rate me,plz.
Feb 04, 2010 | Casio Atomic-Solar MTG900 Watch
Left my decade eco watch in draw and forgot how to recharge in sun and cant find my manual
Your watch should recharge by itself just sitting in the sun(4 hours) or near a lamp(12 hours). Don't place it so close to the lamp or on the dash of your car as the heat can damage your watch. Once charged it should run for weeks to months depending on which model watch you have. If it doesn't keep a charge for long it may need a new capacitor which runs $50 to $75. That is rare however. Charge it up and set it. Good luck, Michael
May 13, 2009 | Citizen Watches
Bushnell Neo Plus GPS Watch Logo
81 people viewed this question
Top Bushnell Watches Experts
Steve
john mabry
Are you a Bushnell Watch Expert? Answer questions, earn points and help others
