Question about Dell E153FP 15" LCD Monitor
Message error When I power on my computer a box comes on with a message dell E153fp, then a lock that opens up. It keeps flashing on and off
    Sergeant:
    Champion:
  • 233 Answers
Can you mention the exact error message that appeats on your screen.
Posted on Jun 27, 2009
The screen on my computer (dell E153FP 15" lcd) keeps going black everytime I turn it on. I can still see a very dark picture and the green light is still on but I can't see much. Usually I just turn it...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd. www.lcdrepair.us
May 20, 2010 | Dell E153FP 15" LCD Monitor
Power light and screen keeps flashing on and off. No picture just a black screen.
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | Dell E153FP 15" LCD Monitor
Dell E196FPf monitor power problem
generally dell monitors open from the bottom they have slight indented flat spaces for a small flat head screw driver to twist and pop the frame apart I start on the bottom left and work my way right and then open the sides carefully and last the top.
Please rate if helpful
Jan 14, 2009 | Dell E153FP 15" LCD Monitor
Menu keeps popping up; Stuck buttons perhaps?
Yes, a stuck key would be a likely culprit. Sometimes a key will get stuck out of just plain useage/wear, or, pop or other liquid spill or splatter will result in a sticky key. Press on the suspect key-compare to another key- different feel will tell you a problem exists.
Low cost keyboards don't generally have the life expectancy as older higher quality ones. Laptop keyboards are also more fragile, and subject to problems.
Dec 23, 2008 | Dell E153FP 15" LCD Monitor
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Jul 06, 2008 | Dell E153FP 15" LCD Monitor
Power green light flash
I suspect that you either have a loose connection or more likely bad solder on one of your boards. Check out this link for videos on opening the unit
http://www.lcdrepair.us/Installation.html
Iwould check all conections for a tight fit and closely examine the solder on the boards. You can use a pencil or something non conducting to push on individual parts after opening the back to isolate the problem..
Jun 19, 2008 | Dell E153FP 15" LCD Monitor
Dell E153FP 15" LCD Monitor Logo
128 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
