Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
Why buy if it cant be fixed
No brush replacement for over priced equipment
Where can I get replacement brushes for an unidentified leaf blower?
If it is unidentified, I am curious as to why you think you can get brushes. You need to know the make and model. If it is obsolete, then it is the end of it. No one supports it anymore. You cannot get parts anymore. Buy a new one. You could try buying a set of brushes from another model that are larger, and carefully filing them down to fit. I have manage to get this to work sometimes, but to be honest it is not worth the time and effort and is only worth doing if the tool is very valuable as it takes lots of time and patience. Buy a new one.
Feb 26, 2016 | Garden
Where can i buy carbon brushes for my craftsman leaf blower 358 799 400
Parts for Craftsman equipment can be obtained at you local Sears store.
Jul 30, 2014 | Dewalt Dw4902 1-inch By 1/4-inch High...
Camshaft sensor
I shop Pelican Parts and partsgeek both have OEM stuff
Nov 07, 2013 | Mercedes-Benz C-Class Cars & Trucks
I have a aeg ph38 electric 800 watt chipper hammer, i need to find carbon brushes and the carbon brush holders for the tool.
RE AEG PH 38 Brushes go to local hardware storeinthe miscelleanous everything aisle and look or a SKIL brush set exact size match $4.50 US cost I fixed mine today. Brush holders another issue
Apr 25, 2011 | Garden
I have to use a hammer to hit the starter of my 1994 Ford Ranger to get it to start. How long can I keep this up or is there another way to do this until I can afford to replace it?
well the hammer could work for a month or a minute. on a bright note normally when a starter is going out on a ranger you can save yourself a lot of money by fixing your starter rather than buying new. the common problem with them is that the brushes inside the starter wear out. these brushes are easily replaceable. once the starter is out look at the backside of the starter and you will see 2 small bolt heads. these bolts come off to expose the inside of the starter and the first thing you will see inside is the brush assembly. the brushes can be removed (the wire coming out of the starter is part of this assem). i'm not sure if they are so;d at autozone, etc. but most areas have an auto electric shop that can get the brush set for you for a fraction of the price of a starter. hope this is of assistants!
Aug 28, 2010 | 1994 Ford Ranger Supercab
Sourcing motor brushes for E675 jazzy motor?
Hi Lane. What happened to your old brushes?
Be carefull fitting different brushes to your machine. If you do, make sure that the brushes you use are also for a 24 volt DC motor. Different voltage motors have different types of material used for the brushes, they can damsge your commutator if you use the wrong ones.
If you find some that are slightly to big, it is Ok to carefully file them down to size.
Contact a local service agent, they often have used brushes that still have a bit of life in them.
I often use brushes from one brand in other brands of machine, and have used brushes as well, but we are probably too far away in New Zealand.
Good luck. Neil.
May 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Awful grinding sound and smoke coming from vent after 8 seconds.
MAGNTRON SHORTED . IT CAN BE REPLACED need to have proper equipment to discharge old magntron to replace . will need proper equipment to check for microwave leaks when done . you will need to down to take it apart, and send it out for repair .....price between 200.00-300.00 to repair warrinty 90 days ......... its up to you but if it was mine i would replace it ..... can you please rate this answer and give me as high as you think i deserve , i want to stay here and help but i need higher rateings to do that , thanks CACTUS BOB
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Continually spinning
indesits dont have carbon brushes they have a module which controls everything to your tomer if this is faulty or your timer then its not worth doing too much in money to replace get a hoover or candy same machine just ones the uk model and the other is the us model dont go for hotpoint though because indesit own hotpoint now and there changing the carbon brushes to modules which is a big mistake alot dearer to replace then the carbon brushes but maybe thats why there doing so customers have to buy another washer check the price by going to indesit customer support web site but i always keep customers away from indesit due to that module some hotpoints are still the carbons but some arent cheaper to buy a slight damaged from a washer repay shop they usually have damaged at a fraction of the price save at least £125 per washer or buy a repossed one may off been used at the most 10 times nothing wrong with them and you will save £200 plus m8
Aug 23, 2007 | Indesit WA 115 Front Load Washer
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
