Question about Garden
Winch wont winch under load - Garden
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
Ever time i use my winch it kill the motor
Might have corroded battery terminals which would cause the alternator to be loaded from the current demand from the winch that it is killing the engine.
Try cleaning all battery connections and if that doesn't work, your battery may not be able to handle the current surge of the winch due to age.
Jan 12, 2015 | Polaris 2014 Sportsman 570 EFI
The special rod will not raise tire.Under load the rod mechanism slips from winch connection.What can I do?
try one that has the same or better end also try lifting tire up while turning and you can lower in down and lubercate it with spray lube and try again
Sep 30, 2014 | Cars & Trucks
Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
Will a nissian titan tire jack fit into a pathfinder to let the spare tire down
Most under body spare winches are driven by either a cross or a loop on the end of the bar. The winch will be a hollow bar with a slot cut across it so either will do the job. Remember that the winch is locked and requires some initial effort to release the clutch in the winch so that you can wind it down
Jan 22, 2014 | Cars & Trucks
Electrical diagram for 8000lb champion winch
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Jul 22, 2013 | Champion International Champion 8000lb...
Electric winch
Is there a load switch on winch
Jul 13, 2012 | Electric Superwinch 12 Volt DC Winch -...
The winch on my 518c cable skidder wont work right !!
I would check the hydro fluid, if you run low this may happen. also the may be a flow adjustment on the winch itself maybe an Allen fitting. Good luck
Apr 13, 2010 | Heavy Duty Associated Equipment 6002B...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
