Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500BWW not dispensing softener
Not dispensing softener during a normal wash cycle. In service mode ran it thru a quick service run and it dispensed the softener as it should by opening the valve and allowing hot water to flow to the softener cup. However in a normal wash cycle it will not dispense the softener. Wash/rinse is always set on cold/cold, and clothes are usually washed on the cotton/strudy setting.
Coldcut
  • 1554 Answers
SOURCE: Maytag MAH 3 Neptune Washer doesn not dispense the fabric softener
The only thing you can do is check the hoses and clean them out.
if you open the top (3 screws in top rear )
you can see the hoses that feed and drain the dispenser,
it will take a pair of pliers to remove the clamps. don't lean on the plastics as they will break.
if they are clear then you may have a leakage of the seals from the water supply side. these valves can build up deposits from hard water and not fully close.
you can disconnect the inlet before it gets to the dispenser and watch for leaking. the valve is a sealed unit but can sometimes be fixed by removing and soaking in a lime remover, drying and reinstalling.
Posted on Jan 29, 2008
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
IFIXALL
  • 868 Answers
SOURCE: Automatic fabric softener dispenser does not dispense anymore.
replace the control board
Posted on May 26, 2008
SOURCE: Maytag Neptune FAV6800AW - Fabric Softener dispenser doesn't empty
I had a similar problem with the fab. softener chamber. Clean
out the buildup and it will drain. To do this, remove the cap and wipe out the softener. Also, be sure to wipe inside the drum, just below the dispenser.
As for a water flow to the dispenser- You will need to remove the plastic portion of the lid. Start with the detergent dispenser, then gently remove the bottom corners of the lid. Then are held by two plastic clasps. Then gently remove the "L" shaped plastic holders. Use a pipe cleaner to clean out the tube where the water flows directly out of the unit, before entering the lid. I did this last night, and it works beautifully!
Posted on Jul 19, 2008
SOURCE: Neptune stackable washer...
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL fabric softener cup seems to be clogged, what do I do?
If your machine is a FAV6800AW/FAV9800AW see if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove gunk build up.
If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue.
The Service Manual for reference use and care guide has some info
Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Bleach wont drain during washing
You may have a clog on that side where the water comes into it, or the dispenser valve is not opening that side.
There is a service sheet inside the bottom of that front lower access panel on the right side wall, you can go through the diagnostics to test the water flow to that side of the tray.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune Washer dispensers
Replace the wax motors for both the bleech and softener
Sep 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6500
Sounds like some sort of broken support or spirng underneath. Flip it over and look. Expect a little water to run out though.
Feb 28, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
472 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
