Question about Neff B1644 Electric Single Oven
Grill element needs to be changed - Neff B1644 Electric Single Oven
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
I have a delonghi oven. The grill element smokes violently as the element heats up. Does it need a replacement grill element?
no you dont need a new grill its just collecting fats from when you roasting and burning off when you initially heat the grill. if you use the grill more often it wont build up as much. covering the roast can reduce the saturation and perhaps a slightly lower temp will help reduce splattering.
Aug 02, 2010 | Ovens
The element on my grill inside the oven is not heating up?
There are two possibilities of what is wrong here.
One is that the grill element has failed and may need to be replaced.
Second it could be a failure in the grill element control circuit (in effect the temperature regulator) thus not allowing power to the element.
Most likely it will be the grill element.
You would need to test with a multimeter to determine which a) by checking the resistance reading of the element and then b) the continuity of the control circuit.
Jan 20, 2010 | Zanussi ZHQ575 Electric Double Oven
Can I change the grill element myself? I assumed it just plugged in at the rear and have removed the two screws holding element to top of oven. Now I wonder if the steel plate at the back is itself bolted...
The grill element is not usually a 'plug-in' device.
You will have to remove the back of the oven/grill and disconnect it from the back before you can withdraw it from the front.
Remember to switch off the power before removing the back.
Jan 12, 2010 | Bosch HBN 131560B / 131520 hot-air...
How do you change the grill element ? on a Neff U1421N2GB/05
screw at top of element is for support.. there are either 2 screws at the rear of element bracket holding it or access to behind the rear panel is required as there are 2 nuts holding the grill bracket to rear cavity. please make sure power has been disengaged before attemt to repair..
Dec 21, 2009 | Neff U1421 Double circotherm Electric Oven
Grill not working
Yes, you will need to replace the whole element.
Dec 07, 2008 | Zanussi ZHQ575 Electric Double Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Neff B1644 Electric Single Oven Logo
22 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
