Question about RCA RT2280 System
Only humming sound from speakers, rca rt 2250
Only humming
  • 3 more comments
  • puppup52 Jun 19, 2009
    Why is there only humming
    why is tere only humming going on
  • puppup52 Jun 29, 2009
    It hums in all settings
    The humming is happening in all settings
  • Derek Williamson May 11, 2010
    Does it hum when it is switched over to the radio input?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
If its humming no matter what on all inputs, that means the internal electronics are worn out or damaged. This can be from a number of different things and isnt worth trying to have it fixed do the fact it would cost more than just buying a new one.
Posted on Jun 29, 2009
Kenwood cd-203 5 cd humming sound
Check your RCA cables to make sure that they are not dirty, tarnished or not completely plugged in. Also, try switching to different (working!) RCA cables to see if that fixes the noise problem. Good luck!
Jan 13, 2013 | Kenwood CD-203 5-Disc CD Changer
Tv works but no sound
Hello Jjwpod hi, to find where the trouble is, you need to place ear near speakers, you should hear a humming sound, adjust the volume up or down, the humming sound also goes up or down, this means your amplifier is working, no hum means trouble in amplifier.
summary:
No hum: trouble in amplifier, speaker connection.
Humming, but no audio: problem before amplification, most likely the Sound IF stage.
Sep 16, 2010 | RCA F27615 27" TV
Making loud humming noise only.but if you plug
If I understand this correctly: with NO input or cable attached it hums; with an RCA cable attached it works. (What does 'some' mean in this regard?)
You say that connecting the RCA cable improves its sound. That tells me you're supplying a ground through the RCA cable for stray voltage in the sub.
It seems there may be a basic power issue if it hums with no input. Sometimes a given power source in a home may be wired differently than others or may insufficient grounding, which can result in hum. Try reversing the sub's power plug or move it somewhere else.
Since the sub contains its own electronics it is also susceptible to strong external magnetic fields. Keep it and any signal cables leading to it some distance away from other electrical devices like TV's.
Apr 08, 2010 | Velodyne CT-100 Speaker
Popping and cracking noise from rt side speaker
You probably have a bad solder connection or an intermittent part failure in the right audio amplifier or its source circuitry. Put in a call for warranty service.
Dec 08, 2009 | RCA Televison & Video
Only humming noise from speakers
The humming is probably caused by failing filter capacitors, these are usually quite large, also look for cold solder joints around parts the heat and cool continuously. Please post an update to further troubleshooting, if this doesn't solve the trouble.
Jun 19, 2009 | RCA RT2500 System
Humming sound coming from transmission pan when key on
yes you need a filter on you amp to stop the noise through your speakers any car audio shop should be able to solve your problem
Jun 01, 2009 | 2008 Dodge Charger
Humming sound to speakers from amplifier
It sounds like you may have a ground loop issue. I'd start by checking all the power and ground connections. Then disconnect the RCA wires from the amplifier. If the hum goes away then you should try grounding the stereo to a better grounding point, the factory grounds are usually not very good at all. Then try it again, if it is still there try replacing the RCA"s.
If the hum is still there after you've redone the connections and replaced the RCA's, you may need to install a ground loop isolator.
Both www.crutchfield.com and www.sonicelectronix.com sell good ones.
Hope this helps
Mar 28, 2009 | MTX X Thunder 1000XD Car Amp
Rca 2250
Sounds like your right side output is shot. And yes it can be fixed, but the cost factor would be higher than what you paid for the set itself. First see if your inputs are working correctly, this also could be your problem. Check all your connections.
Dec 29, 2007 | RCA RT2250 System
No Sound
Maybe the speakers are no good. Have you tried hooking up a different set of speakers?
Oct 11, 2007 | RCA RT2500 System
Problemas con RT 2250
http://www.rcaaudiovideo.com/Cultures/en-US/SearchResults.html?search=RT2380
Jan 11, 2006 | RCA RT2380 Home Theater System System
RCA RT2280 System Logo
375 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
