Question about Xantrex Technology Electronics - Others
I have lost my charger for Xantrex 300 that plugs in to the house. Can I order a new one>
4 Suggested Answers
  • 303 Answers
SOURCE: I lost my ac charger and need to know where to order a new one
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for CURTIS D8017
Posted on Mar 05, 2009
mwoodring1
  • 496 Answers
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
Posted on Jun 21, 2011
Gozer
  • 435 Answers
SOURCE: I have the Xantrex Freedom
Upgrade to one of the Freedom remotes, the 458 has different software, and features than the old Freedom 1500.
Posted on Sep 17, 2011
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
Why does my Freedom 100 Watt Inverter/Charger remains in bulk
It sounds like a bad battery mine did the same but it was a much larger unit changed the house AGM Batteries and works perfectly
Jun 09, 2014 | Xantrex Technology Xantrex 458 10 12...
I plugged it in waited 48hrs and it did not charge
I would try a different power outlet.
If that does not work, you more likely have a defective unit.
In that case you would like to contact the store or manufacturer in order to replace it or get your money back.
Good luck.
Mar 06, 2011 | Xantrex Technology Xantrex Xpower...
Trying to charge but all I get is a clicking sound and flashing light while charging
had the same problem, was going nuts. Then I pushed the button for the flash light charger and it stopped clicking. Here's hoping it works
Aug 28, 2010 | Xantrex Technology Xantrex Xpower...
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
I bought a new Powerpack 300 and never had a use for it. It was plugged in for a year and when I decided to test it everything worked until I plugged in any AC appliance.. It just doesn't seem to have the...
Your battery is likely damaged from being plugged in for a year. The battery is a sealed lead acid battery inside, probably a 12 or 17AH job. Proper way to store a lead acid battery is to keep in cool dry location, and top off charge each month or two by charging according to manufacturer guidelines.
If you can figure out how to get into the case, you can replace the battery.
Aug 05, 2009 | Xantrex Technology Xantrex Xpower...
Don't know voltage setting for charging this unit.
You can use any adaptor that supply 12V or more. If you have at least 800ma of current, and 12V or higher it will do the job. Higher voltage rating will charged it much quicker but you have to watch it.
Jun 18, 2009 | Xantrex Technology Xantrex Xpower...
Xantrex PowerPack 300 will not hold a charge
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
Mar 28, 2009 | Xantrex Technology Xantrex Xpower...
Electronics - Others Logo
24 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
