Question about JBL Cinema SB400 Soundbar w/ Subwoofer
Subwoofer is there any compartable sub to go with jbl sb 400
2 Suggested Answers
  • 2326 Answers
SOURCE: JBL SUB ACR10 SUBWOOFER
I would suggest to check the rectifiers first, very unlikely that the capacitors became shorted.
Posted on Sep 04, 2008
How do you bi-pass a jbl subwoofer sb 400 to a sony str- dn850
If they both run the same ohms, why would you want to by-pass it? Just disconnect the sb 400 altogether and wire straight into the dn850. If the 850 is amplified (plugs into a wall outlet), however, you may wind up with some distortion, especially if the signal coming out of your receiver also is hot (amplified.)
May 09, 2016 | Sony Audio Players & Recorders
JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Nov 10, 2009 | JBL PB10 Subwoofer
JBL PB10 has lost power even though still plugged into wall, any suggestions?
Do you mean like the subs power lights dimming when playing it at volumes it once had no problem playing, or loss in sound, distortion?
Oct 10, 2009 | JBL PB10 Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Sub Woofer will not work with my other two speakers.
ok SB is for surrond back. but i think i now what the problem is. if your receiver is in multi channel decoding some times the bass will olny come out of your main speakers. and how to change this is go to SET UP in main menu on your receiver make sure you got NORM SET on and then go over in tell it has your main speakers highlited and change that to SMALL not LARGE and sarry for the spelling hope i helped
Mar 06, 2009 | Sony STR-DE597 Receiver
Sep 04, 2008 | JBL PSW-D112 Speaker
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Jbl subwoofer
There is actually some good news.  I had this problem with my PB10s (1 have 2 PB10s and 2 PB12s) It is one of 2 things, the first is that it could be a capacitor and resister combination on the amplifier board (which was the fix for our PB10 with the same problem), or 2nd, the AMP IC, which is not available for the PB12. hmmm
Sep 10, 2007 | JBL PSW-D112 Speaker
JBL Cinema SB400 Soundbar w/ Subwoofer Logo
21 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
