Question about Golf
My 1992 club car has no spark
Ran last summer then quit running all of the sudden
66 chrgr
  • 1011 Answers
SOURCE: car turns over but wont start
if you have spark after you turn the key off the module is bad in the distributer replace it and you will fix the problem thank for your ansewr.
Posted on Feb 04, 2009
  • 57 Answers
SOURCE: crank, no start 98 wrangler 2.5l
crank sensor likely-may be distributor sensor but my 98 sport was crank sensor situated in bell housing timed by flywheel
Posted on Sep 15, 2009
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
dcramer531
  • 1654 Answers
SOURCE: 1992 115 hp V4 2
The carbs on 2 strokes are always needing a little adjusting, either your plugs are somewhat foulded, carbs gummed up from setting, restriction in fuel delivery, linkage could also be biding slightly. These are the general issues, any more would require a tech to get hands on and test them. But if your savy enough to adjust the carbs, just bump the idle up a tad after you check everything out. I am guessing that this may clear up on its own, but may need a bump.
Posted on Mar 27, 2011
  • 16 Answers
SOURCE: Was driving my 1998 gas club when suddenly quit pulling engine runs good
Check the drive belt.
Posted on Jun 19, 2014
I have a 1988 club car gas golf cart. I have done everything that I can think off. cleaned carburater, drained all fuel tank, replaced battery, replaced some of the gas lines. golf cart will only run...
When you say cleaned carburater did you take it all apart and spray carb cleaner through all the ports, it only takes the smallest debris for it to not run properly
Sep 07, 2017 | Cars & Trucks
Crank, no start 98 wrangler 2.5l
Sep 15, 2009 | 1997 Jeep Wrangler
Engine ran fine stopped at red light it just stopped running.
Make sure the modual and coil is getting fire and that the engine is got good ground. But it sounds like you got a bad coil.
Sep 14, 2009 | 1992 Ford Club
Dead 92' Ford Econoline
Have you tried replacing the coil?
Jul 21, 2009 | 1992 Ford Econoline
I own a 1992 hyundai sonata 4l2.0.,which I keep in Europe and drive it every summer.It has 56000km on it.Last summer it was running rough at idle and sometimes it wouuld stall when i put it into gear.Also,...
If car has carburetor, the float inside the carburetor is not closing off the gas flow inside reservoir, causing gas to flood in to intake barrel, if Your car is fuel injected the temperature sensor, is next to the temperature gauge sensor, usually replace both
Jan 22, 2009 | 1992 Hyundai Sonata
In cold weather engine/car vibrates
is it at idle if yes change your idle air control valve.
Dec 17, 2008 | 1992 Ford Club
No spark
What about battery and alternator (serpentine belt).
Dec 05, 2008 | 1992 Mazda MX-3
Golf Logo
Top Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a Golf Expert? Answer questions, earn points and help others
