Question about HP Deskjet 350 InkJet Printer
What to do when the carriage of the cartridges HP Deskjet 350 doesn't move?
The carriage of the cartridges doesn't move. Screen says: one or more cartridges appear to be missing or damaged. Install or replace the affected cartridges....but how?
    Habit-Forming:
  • 54 Answers
I think your not using this printer log time...?????
just conform before its working or not after replacing new cartridges it showing this erorr??
if it is not working when you installed new cartridges, your new cartridges fault other wise problem with carriage PCA board
Posted on Jun 25, 2014
Bubbabear64
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
Riztech
  • 731 Answers
SOURCE: I just purchased an HP
Hi
If the printer is out of the Box, don not try any other ink cartridges, becoz you must use the HOST ink cartridges that is shipped with the printer for the first time.It seems that it is problem with Host ink cartridge.
You can check the cartridge whether its a Host ink cartridge or normal one by looking at the serial number.If Serial number starts with C9, it Host; if it starts with C8 its normal one.
Only HP can replace it , none of the store sells Host ink cartridges, they sell the replacement ones.
You can either call HP tech support or, return the printer to staples.
Thank You
Rizwan
rizwan84tx@gmail.com
Posted on Dec 07, 2008
SOURCE: Carriage error Hp F2280
Same thing happened to me and I took it back to the store, where I bought it from. They replaced it with a new one and told me that it didn't have any software installed, like if you have a motherboard without bios ..
Posted on Dec 23, 2008
professor_sc
  • 180 Answers
SOURCE: ink cartridge problem! The following ink cartridges appear to be missing or damaged.
Solution :
1. clean the ink cartridge contacts both in the printer and the cartridge with a lint free cloth or a cotton swab. and try inserting the ink cartridges again. if it wont work proceed to step 2.
2. unplug the power cord at the back of the printer
3. press and hold # and 3 keys at the same time and plug the power cord back in. Do not release the two keys. wait until the printer would say "partial nvram reset" or anything that says "reset". if this still would not resolve the problem
4. do the same process as 2 & 3 but instead of # and 3 try # and 6. instead of saying "partial nvram reset" it should say "semi-full nvram reset". and if it would not work better go to an onsite technician. but if your printer if brand new return it to the retailer and exchange it. but before you do that try calling HP technician they would instruct you to the things i have given you. Just tell them what you have had done and asked them to replace the ink cartridges. This are the informations the agent would ask you about the ink cartridge
part number and also the expiration date.
try to ask for a replacement first if it would not resolve it. then go to a technician. I could not assure you that a technician could fix it because i have troubleshoot this kind of problems and there are alot of printer parts that needs to be fixed. Usually i suggest my clients to buy a new printer instead
Posted on Mar 07, 2009
SOURCE: HP Deskjet 5550 cartridge carriage stuck
I have had this same problem a few times, not due to changing the cartiges, but following one of my kids yanking on a peice of paper as it was printing. After I tried all the unplugging and clearing and re-starting, the arm was still stuck on the left. I read on some forum (can't remember where) while the printer is off, to gently push/pull on the cartiges until they un-jam or start to move. I flet like I was going to break it, but it has worked every time.
Hope this helps osmeone else!
Posted on Jun 18, 2009
Hp deskjet 3920 door open error
Open the door, left side above on off switch there is contact for door sensing switch, press that check carriage assm moving right side?.. *if yes insert small peace of paper in it, use it..But if you want to replace the cartridges remove the paper object.** if carriage assm not moving open the upper cover check the switch..
Sep 20, 2011 | HP DeskJet 3940 InkJet Photo Printer
DeskJet 460. Opening ink cart cover does not make cartridges slew to centre.
Hi
This is a problem with the ink cartridge. Maybe your cartridge is bad and needs to be replaced. But because the carriage is not moving you can turn off the printer and try to move it with hand it should move now. Once out of place try to remove both the cartridges and turn on the printer. Now when it says error then open the cover and the carriage will move to center and you can install the cartridges back in the printer and try.
RATE MY SOLUTION
Jul 06, 2011 | HP Deskjet 460c InkJet Printer
Where do i install black ink cartridge?
Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot
May 29, 2010 | HP DeskJet F380 All-In-One Printer
Hp 812c cartridge cradle is stuck on the right, not moving to the
unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
Feb 27, 2009 | HP DeskJet 812c InkJet Printer
Cartridge of My HP Deskjet 3550 Won't Move?
Friend,
Either the carriage is stuck in the service station or on the opposite side of the service station - at least it's jammed somewhere. The motor starts but cannot move the carriage.
I'd suggest you'd contact your local HP support, they should be able to help you fix this problem, or take the printer in for service if irt's still under warranty.
//Al
Jan 28, 2009 | HP DeskJet 3550 InkJet Printer
Oct 17, 2008 | HP DeskJet F380 All-In-One Printer
Lift the cover up.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6540
The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
Mar 19, 2008 | HP DeskJet 6540 InkJet Printer
Hp deskjet 1180c
try this:
  1. place good cartridges
  2. turn off printer
  3. press and hold power button until printhead is moving
  4. release power button
  5. your printer should be working again
Sep 06, 2007 | OKI MICROLINE 5521 Matrix Printer
HP Deskjet 350 InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
