Question about Eton American Red Cross ZoneGuard Radio
No sound on any band at any volume - Eton American Red Cross ZoneGuard Radio
Lg tone 730 too loud
Here is a solution: Remove rubber ear buds from the device. take a breathable band-aid package. Use two layers of band-aid cut into very small circles..stick the 2-ply band-aid circle to the headphone. Replace the rubber ear bud. This will reduce the sound sufficient to carry on!!
Feb 02, 2013 | LG Tone HBS-730 Bluetooth Headset- Black
Samsung gt-c3322 speaker not working
My phone speaker volume not working . out of calling small sound.use volume button increasing . no small sound
Jun 24, 2012 | Samsung GT-C3322 QUAD BAND DUAL SIM...
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
I have a L46FHD37 lcd tv how can i reset it
The Sound menu lets you adjust audio output. To access the Sound menu, press MENU on the remote, and then select Sound from the Main Menu. The following audio items can be adjusted:
Equalizer The five-band graphic equalizer lets you adjust the audio frequency settings. You can select one of the five-band Equalizer Presets or create your own personal preset.
Sound Preset Allows you to choose a specific Sound Preset. Press the right arrow to cycle through the options: Standard, Movie, Voice, Music and Personal.
Frequency Range Displays the different graphic equalizer bands set for each Sound Preset option. Choose a band and make adjustments. When you make adjustments, the Sound Preset option automatically changes to Personal. Press the left or right arrow button to select the frequency (100Hz, 300Hz, 1KHz, 3KHz, 10KHz) you want to adjust. Then use the up or down arrow button to adjust the level. When you're done adjusting the levels, press the MENU button to exit.
To view the frequency range of another Sound Preset option, press the right or left arrow until no band is selected and Frequency Range is highlighted. Then press the up arrow to highlight Sound Preset.
Sound Type Controls the way the sound comes through your speakers. The options available vary according to the input selected.
Mono (available for regular TV viewing only) Plays the sound in mono only. Use this setting when receiving broadcasts with weak stereo signals.
Stereo Splits the incoming stereo audio signal into left and right channels. Most TV programs and recorded materials have stereo audio. The word Stereo appears in the channel banner when you tune to a program that is broadcast in stereo.
Sound Mode Provides special processing through your speakers (depending on the setting you chose as your Sound Type). The available sound modes are:
Off Does not give any special sound processing.
SRS WOW Gives a surround effect with more bass. (available for models L42FHD37, L46FHD37, and L46FHD35) SRS TurSurround XT (available for models L42FHD38, L46FHD38, L52FHD38, and
L40FHD380) Dynamic Bass Improves bass output. Displays a choice list of available settings you can adjust: Off and On.
Balance Press the right or left arrow buttons to adjust how much audio is sent to the left and right speakers.
Auto Volume Level Reduces the annoying blasts in volume during commercial breaks, and also amplifies softer sounds in program material. Eliminates the need to constantly adjust the volume.
Internal Speakers Turn on or off the internal speakers. If you have a device connected to the AUDIO OUTPUT jacks on the back of the TV and you want to control the sound by the device instead, uncheck the box.
If you would like for me to send you the user manual, please send me an email to LBrown18062@hotmail.com. Put "RCA L46" as the subject and I will send it to you.
Mar 30, 2012 | RCA L46FHD2X48 46 in HDTV TV
My volume on the xm radio band is noticeably lower than the regular fm band. Is there anyway to adjust the volume on the xm band tto make iy louder?
XM radio usually has lower volume than regular FM/AM bands. But there 'might' be an adjustment you can do with your radio, depending on your unit. Please indicate the brand and model of your radio so I can check.
Sep 24, 2011 | Car Audio & Video
If I stretch a rubber band around the volume knob on cb, keeping pressure on it, it will stay on.
Sounds like the switch is worn out. Time to visit the CB Radio Shop and have them replace the on/off/volume pot.
Jul 16, 2011 | Galaxy Radios DX 77HML Base CB Radio
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
When i played at church with all the band it happens that wen I'm playing for about 20 min. I try to up the volume or use a booster pedal for leads and the volume stays the same I up the master volume and...
Maybe the band is too loud and drowns you out. Seriously, when the band is there, not playing anything, try the volume. Add more instruments, constantly checking the volume. My guess is to tell the group to lower their volume so the parishioners don't go deaf.
Jun 28, 2010 | Electric Measuring Tools & Sensors
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Making the drum sound come from the tv instead of the plastic sou
eh, turn up the volume of your tv. When me and my buddies play rock band we turn on the bose surround sound system so it actualy sound like a rockband instead of hearing the drum sticks smaking or the singers horrible voice, or the clicking of the guitar.
Jan 01, 2009 | Nintendo Rock Band for Wii
Eton American Red Cross ZoneGuard Radio Logo
412 people viewed this question
Top Eton Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you an Eton Baby Care Expert? Answer questions, earn points and help others
