Question about Venturer Televison & Video
No signal Existing tv signal fine, tried with venturer 15" no signal
The plastic hinge is broken. can it be fixed?
John, Venturer KLV39150 15" Under Cabinet LCD TV with Built-In DVD Player & Radio parts do not seem available(discontinued item)
Try 2 part epoxy and use a plastic backer to rejoin broken plastic, if possible.
press the helpful button and follow me on fixya for more tips
Feb 09, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Need the remote code for a venturer TV
0281,0288,0280. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 21, 2014 | Venturer 19 inch flat screen TV
Venturer under the counter tv has no sound
Check if all your cables and connection are connected properly..
Dec 19, 2013 | Venturer 15" Under-cabinet Lcd Tv
Venturer Tv to Sky
It sounds like your TV is on the wrong input. Look for a button that says input or source. Depending on the TV this will either provide an onscreen menu to select an input or it will simply scroll through the inputs. Turn on the Sky box and run through the inputs until you see something that looks like your Sky Box.
Jul 26, 2013 | Televison & Video
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
I need a code for a venturer tv for my radioshack 4-1 family favorites remote
Here's the manual, with codes.
http://www.rockabilly.net/files/manuals/15-2142.pdf
I don't see the Venturer brand, you will just have to try different ones until you find one that works. Good luck.
Feb 07, 2010 | Radio Shack 15-2142 Remote Control
Coby 10.5 TV. New doesn't receive signal
you must run set up in the cable mode not air try that if that does not do it i would return it ASAP
Nov 30, 2009 | Coby TF-TV1022 LCD TV
Adding A DVD Player to an existing Digital TV box
You should connect the changer to the tv, not the digital box. It will still get the signal.
Apr 11, 2009 | Toshiba SD-3980 DVD Player
Chevy venture
Solution to your problem ... 1- I purchased from 1aauto.com a pair of Circuit Boards for my Chevy Venture 2003 for 85.00 $ ..free shipping 2 - I Installed them both , all lights now were not working at all. So I checked them and they were all burned ...So I purchased new ones ....Everything was working fine now but now my signal lights were not working left and right .....Checked the fuse box next to the passenger side door .... It was burned . Changed the fuse / Signals are working fine now ....All is good I just did this yesterday evening August 12, 2008 Conclusion ..Change everything going forward so you do not need to run around like I did from one store to another!
  1. Circuit Board : New
  2. Bulbs : New
  3. Fuses : New
Thank you
Jun 26, 2008 | 2003 Chevrolet Venture Passanger
Televison & Video Logo
19 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
