Question about Archos 704 WiFi Digital Media Player
Bloated lithium battery
How to use 704 without batteries
How can I charge a 20 volt lithium battery without its charger? Can I use a laptop charger for it?
Angel why not purchase a 20 volt lithium battery charger . It is better than risking blowing up a laptop charger or the battery.
Google search
charging 20v lithium batteries
and heaps of chargers come up that you could purchase.
Sep 28, 2015 | Drills
Why so long when i'm charging my lenovo a1-07 ideapad
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Hope this helps.
Dec 29, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
My yp-u3 has been drown to water.and d battery is bloating.how do i fix it.
SOAK IT IN RICE COVER IT IN RICE IT DOWN AS MUCH AS POSSIBLE RICE WILL DRAW THE MOISTURE OUT
Aug 30, 2011 | Samsung YP-U3 MP3 Player
Do you need the lithium battery for the calculator to work
Not absolutely. The calculator is normally powered by the four AAA batteries. However, if the AAAs drain, then you'll lose all the contents of RAM memory. The lithium battery will preserve the memory long enough for you to replace the AAAs. So, if you don't care about what you have stored in the RAM, you can use the calculator without the lithium battery.
Aug 11, 2010 | Texas Instruments TI-83 Plus Calculator
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Battery / camera does not turn on
It may or may not be a battery problem. A completely dead battery will not turn the green, red and blue lights on at all, like my bloated and dead original battery. This camera uses a custom lithium-polymer battery that built just for this camera. I don't think you can order one from Che-ez. But if you are savvy enough, you can re-build the battery by taking the old battery pack and the protection circuit board out with a soldering iron, keeping the plastic frame and replace the pack with a similar one that you can buy on ebay for less than US$10 by soldering it back on to the contacts on the frame. Just search "Lithium Polymer 380mAh" on ebay and that is the one that gave mine a second life. WARNING: Do it at your own risk, don't hold me liable if you lose a finger or more from mishandling the potentially explosive Li-ion battery pack. Good luck!
Feb 25, 2008 | CHE-EZ v:u Digital Camera
S2 pro electronic malfunction?!?!
If your lithium batteries are depleted, having them in the camera will shut it down. A common cause of depleting the lithium batteries is leaving them in the camera while using the AC power adapter. For some odd reason, the Fuji engineers did not build in a disconnect circuit when on AC power. You should always remove the lithium batteries when using the AC adapter.
The Fuji S2 will run fine without the lithium batteries, except that you will not be able to use the built-in flash. Fuji recommends that as an "emergency" procedure, but I ran my S2 off NiMH AAs only for my heavy use over four years with no adverse effects.
If you buy the MB-16 battery pack or one of the modified versions for the S2, you would be able to use 8 AA batteries to power the camera, including the built-in flash, and never touch another lithium battery. The MB-16 itself does require some modification in filing off edges around the base and building up material around the post to firmly engage the switch you found.
Sep 29, 2007 | Fuji FinePix S2 Pro Digital Camera
LB-01 CR-V3 lithium Batteries
The Olympus CR-V3 lithium batteries will provide approximately 500 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are not rechargeable.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
LB-01 CR-V3 lithium batteries
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Archos 704 WiFi Digital Media Player Logo
16 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
