Question about Grandstream GXP-2100 VoIP Phone - 4 Line - Two Ethernet - HD Audio - O
Firmware upgrade grandstream
I would like to upgrade my phone. Settings are ok. But I do not know where to start the progress of upgrading.
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
Install XF2 Firmware V4.10
After you have downloaded the file "install.img" from lge.com,connect it to your TV,go to Settings,then System Upgrade,press OK to show the sub items of System Upgrade, choose "Cancel" to abort the operation and choose "Upgrade" to upgrade the system firmware. Afterward,
the system will reboot and the firmware upgrade page begin to show. After firmware upgrade completed, the system will reboot and show the language selection page.
Sep 06, 2012 | LG (HXF1N50SB) 500 GB USB 2.0 Hard Drive
How to update mobile os in Samsung champ?
* Download SAMSUNG KIES as your tool,install it on your computer.
* then you need a CA-101 usb cable.
* Be sure battery is fully charge
* Also stable internet connection is required
1. Open Samsung Kies software
2. Plug your usb cable to phone all through the computer.some driver will install on progress or go to tools tub the click install driver
3. Go to tools tub again and select firmware upgrade settings,ne sure the phone is recognized then click ok.
Oct 06, 2011 | Samsung GTC3300 Cell Phone
Hi Yesterday i upgrading my Samsung wave s8500 firmware. while upgrading internet connection is Disconnect and now my phone only shows one picture on display whenever i tried to USE it... PICTURE i.e One...
Step I: Download the latest version of Samsung Kies from official site of Samsung Kies. The latest version of Kies is: Kies_2.0.0.11044.
OR
You can download it from here: Samsung Kies Download Link
Step II: Open Samsung Kies and connect your Samsung Wave with PC (Wait for driver installation, if you have attached your phone for the first time with your pc)
As soon as Kies will detect your phone it will offer a prompt of new firmware update available, see the screenshot below
Firmware upgrade prompt
Click on UPDATE button
Step III: Now you will face a window of 'Agree to the Terms and Conditions." You can choose the option of save and don't save the information. This option is that, Samsung will store your information of IP and hardware specifications on their servers for 2 years. It is totally dependent on you, which you want to choose.
We would like to recommended you to choose "Allow saving"
Upgrade Terms & Conditions
Hit START UPGRADE button
Step IV: It is strongly recommended not to disconnect your phone from PC until the upgrading process is complete. So take care of it.
Within few minutes (depends upon the speed of your internet connection). Upgrading process will move on and will complete successfully.
Upgrade in Progress
Note: Don't use any options on your phone, while the upgrading process is taking place, your phone will be restarted. DON'T PANIC!
Your phone will come to working state automatically and your Samsung Wave is successfully upgraded to Bada 1.2
Jun 03, 2011 | Samsung Wave S8500 Smartphone
Have an iriver H10 - i turn it on and i get this message. " System files missing. To restore the system files, connect H10 to iriver plus" I did this and nothing worked? Can u help?
upgrade the firmware of your device follow this... How to upgrade firmware
1. Download the zipped file for your region.
2. Unzip the file and you will see *.exe file.
3. Connect your H10 to PC via provided USB cable and power on H10.
4. Once the device is ready, run the *.exe. It will automatically copy the firmware to your H10.
5. The progress bar copying firmware will be shown and your H10 device will give you 'Busy' message.
6. Once it's done, it will give you 'Upgrade Complete' message.
7. Please disconnect H10 with 'Safely Remove Hardware' option on your PC task bar.
8. Turn on the power of H10, go to 'Settings -> Extra ->Firmware Upgrade' and select 'Yes'.
9. Your H10 device will shut off automatically once the firmware upgrade is complete.
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate(EU)_v203.zip&filepath=/file/Down/
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate_v203.zip&filepath=/file/Down/
Jun 06, 2010 | iRiver H10 MP3 Player
I'm attempting to upgrade the firmware on my Linksys BEFVP41 to the latest version. When I click the upgrade button, the progress bar starts, but then the page goes blank before it's halfway through. ...
try downloading the firmware again.
It is a possible corrupted file from the site.
you may be able to download it directly from the linksys site or contact them by phone to check that the file is valid
1.make sure you are downloading the correct version also from the site.
Apr 24, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
While talkin to the other person there is dead air
OK goto your phone settings change your network band from dual to gsm I get that problem with nokia when 3g is enabled please let me know if this works for you
Dec 05, 2008 | Nokia N72 Cellular Phone
Upgrade Problem
Hi cornet913,
It depends on what stage of the upgrade the Wii was at. If it was not near the end then you should be fine. There is part of the process where the Wii clears out the old firmware and replaces it with the new firmware, called flashing. If the Wii was switch off while flashing you might have caused serrious damage to the firmware, which can kill the console.
The only way to know is to try and switch the console back on. So give it a go, in effect if there has been any damage, then it's already done, turning the console on won't make it any worse.
If it doesn't work, call ninetendo, they might be able to repair it for you.
Jul 13, 2008 | Nintendo Wii Console
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Feb 16, 2008 | Trendware TEW-452BRP Wireless Router...
Hello..l6 camera display still not functioning well.
using MPT can not upgrade your phone..........
resetting the phone
menu/settings/master clear/master reset/
default security 000000
you can take the phone to a mobile service center and have them upgrade the firmware on the phone for you....but as always their will be small fee to have that done.
Nov 10, 2007 | Motorola Mobility L6 Cellular Phone
Grandstream GXP-2100 VoIP Phone - 4 Line - Two Ethernet - HD Audio - O Logo
27 people viewed this question
Top Grandstream Lands Phones Experts
ray gallant
spy1309
james laughton
james laughton
Are you a Grandstream Lands Phone Expert? Answer questions, earn points and help others
