Question about Medline HCSFSATSPORT: FingerSAT Sport Oximeter
Error 7 was working fine then error 7 occured. now won't read accurately.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 118 Answers
On this model of SpO2 monitor from Medline, the "err 7" means the sensor has reached its end of life functionality... Basically it means it is time to buy another SpO2 monitor. I have a dozen of these in a rehab facility and have to swap them out every couple of years when I get this error code. I found this out a few years ago from Medline Support. This is why the warranty is 2 years (works out well that way, don't you think?).
Hope that helps out some.. sorry for the bad news...
Thanks!
Stan Skaggs
Posted on Oct 16, 2014
Avanquest checksoft 1935 occured during installation of assembly component
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL
6) Erase the previous and enter the following number:
4294967295
7) Click okay and restart computer
8) Everything will be okay, ENJOY! try to install the package again.
Jan 14, 2014 | Avanquest Checksoft 2007 Home & Business ...
Nero 7 won,t install properly
u either ran out of memory/internet signal..or .ur operating system cant handle it..
Jan 08, 2014 | Ahead Software Nero 7 Essentials Suite...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
HP d220 mt won't boot from a windows 7 install DVD....Will boot an XP install CD
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
Hope it helps.
Nov 28, 2012 | Computers & Internet
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The message prints out from my HP Officejet 7410: A communication error occurred during the transmission. Result Error 232* It was working fine before, now it won't fax 2 pages.
Actually Error 232 is mostly because of the Remote machine still we can try one thing in your machine ie - we can disable Error correction mode
How to disable it?
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
Try to send fax now .. It should work
Please Vote for me if it works
Jan 04, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Printer error can find any paper jam but still wont start!
Yes it could be. Some pin at chip of ink tank, read when printer turning on (reading presence/existence). Some pin read when start to print (reading "information" ). If there are some pin not connect, status monitor (ink level) is ok, but when start print error accured.
May 29, 2009 | Epson Stylus® RX640 All-In-One InkJet...
Medline HCSFSATSPORT: FingerSAT Sport Oximeter Logo
149 people viewed this question
Top Medline Health & Beauty Experts
rugby prop
ka4iup
ka4iup
Are you a Medline Health and Beauty Expert? Answer questions, earn points and help others
