Question about Craftsman 19.2V C3 DRILL/DRIVER
Chuck is stuck open on craftsman 19.2v drill - Craftsman 19.2V C3 DRILL/DRIVER
5 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: chuck is locked in open position
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
Posted on May 25, 2009
  • 142 Answers
SOURCE: locked drill chuck
i have the same tool and have had the same problem
i use 2 large prs of channel locks(water pump pliers) to break the bond
Posted on Jul 06, 2009
  • 165 Answers
SOURCE: Craftsman 14.4 drill chuck stuck in open position
Look inside for centered screw and remove.
Posted on Feb 27, 2010
  • 670 Answers
SOURCE: keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Posted on Jun 04, 2010
Testimonial: "Thanks for your solution - it worked great! Robert"
Craftsman 19.2v drill. What is process remove the chuck. The back side of it has 17mm dual flat spot. I tried 17mm open end thin bike wrench but I cannot get the chuck to unscrew. I need it off in order to...
Hi Charles! The chuck is fixed to the spindle by a bolt (with Ph2 or hex head), you can find the bolt head if you look directly into the chuck (with its jaws completely opened). You'll just need to fix the chuck (with your hand most probably), and unscrew that fixing bolt (might be with left-hand thread! - don't use excessive moment, first try it gently both ways). After removing the bolt you'll just need to gently tap the bottom of the chuck - through a piece of wood - with a hammer, to remove the chuck from the spindle. Gently is the key word - in order not to damage the chuck and ball bearings/gear set of the drill.
Below are 2 reference links from Craftsman and Sears Parts catalogue - may help you as well.
Good luck! Craftsman C3 19 2 Volt Lithium Ion 3 8 in Drill Driver Kit Craftsman Drill Parts Repair Parts
Mar 28, 2015 | Craftsman Drills
Drill will not rotate
Did you have to set the chuck into the spindle, or when you got the press, was the chuck already attached to the spindle? With the drill press I got (different brand), I had to set the chuck in the spindle and I put pressure on the chuck to set it in by placing a bit in the chuck and drilling in a piece of wood, which placed pressure on the chuck. If that's not the issue, check to see that the pulleys are turning ( flip the top open). Also check the tension of the pulleys (machine OFF) If there is nothing apparent or obviuosly not working, and if the press is new, yes, I would return it.
Nov 09, 2013 | Craftsman 23 hp 10" Drill Press with Laser...
Chuck is stuck open thank model973227070
Try spraying WD40 or similar into jaws of chuck and alow a couple of minutes for it to penetrate before trying to close it.
Also use cloths on the chuck while tightening to get a better grip.
Feb 27, 2011 | Craftsman 3/8" Corded Drill
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Chuck is locked in open position
May 25, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
Apr 12, 2008 | Dewalt 18 Volt Compact Drill Kit
Craftsman 19.2V C3 DRILL/DRIVER Logo
101 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
