Question about Canon Office Equipment & Supplies
E0002250001 canon ir 4570
  • 153 Answers
SOURCE: can any one help me canon ir 4570 service manual.
yeah ring canon and try and get one
Posted on Apr 01, 2009
etaf
  • 779 Answers
SOURCE: manuals canon ir-4570
User guide available from here http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Posted on Mar 26, 2010
SOURCE: frozen touch screen by canon ir-4570
Its PDA(touch screen) is faulty contact cannon for new Display or PDA jack is loose
Posted on Oct 05, 2010
  • 122 Answers
SOURCE: I change fixing film still
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Posted on Mar 02, 2011
MUKHTAR
  • 2017 Answers
SOURCE: My photocopy macheni canon ir 4570 keeps on giving the error code e0001-0002
Fuser temperature too high.
Check AC driver board, shorted thermistor. Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 31, 2012
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Ir 4570 print half side print is good and half side print is light how to solve
This problem may be caused by several different issues. It may be a dirty laser unit, a bad developing unit or a dirty or bad CCD unit. All of these will require an experienced technician to troubleshoot and clean or replace. I recommend you call an authorized Canon dealership.
Jan 23, 2017 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
E0002250001 canon 4570
Disconnect and than connect the flexible cable,if not okay,replace it
Jun 27, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
CCD gain correction problem. please check reader assy
Apr 20, 2014 | Canon Office Equipment & Supplies
Jam code 205 in canon Ir 4570
Try to open up the copier where usually the paper goes through and check for any remains of bits of paper.
PS: on the screen shows which side of the printer has to be opened.
Feb 24, 2014 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 4570
Fuser unit / fixing unit problem check whether fuser sleeve is damaged if yes change it or apply fuser oil and white grease on it for smooth rotation....
Jun 24, 2013 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
13 people viewed this question
old marine
old marine
