Question about Kenmore Elite 45986 Front Load Washer
It just beeps when you push the power button and will not power on
  • 6,784 Answers
Hi. the CCU(central control unit), has failed. you will need to replace this damaged control device asap.
Posted on Jun 22, 2009
Lights flashing when turned on, replaced batteries,fuse, in drive position
the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 30, 2016 | Pride Go Chair Power Chair
My playststion will turn on but no picture on my tv
try doing this when it is off (red light is glowing on power button) push and hold down the power button when you first push it you hear a beep while you hold it down you will hear another beep when you do release the button and see if it comes on, I had the same problem with my nephews ps3 and that solved it
Aug 12, 2015 | Sony Playstation 3 (PS3) Console
Get 3 long beeps and 2 short beeps when power on
Likely bad ram... but i need the make and model for the beep codes..
http://www.computerhope.com/beep.htm
Mar 11, 2015 | Gateway Computers & Internet
Hello, I own a 09 Fatboy FLSTF and just resently my left indicator has stoped working. I can not seem to fine the problem Bulbs are fine and they all work when I put hazards on and when the security alarms...
Sounds like button might be dodgy, check that you have power to the button and check that when you push the button you get power out the other side.
Or unplug button, stick your multimeter on continuity (beep function) and probe the terminals and make sure it beeps when the button is pushed.
No beep on any terminals - try another button. If it does beep might be a dodgy wire to/from button for that side.
Jan 20, 2015 | Cars & Trucks
PS3 won't reset
are you trying to get to the safe mode menu?...if so unplug for 1 minute...replug...hold power button (beep) 5 secs next beep is 1...next beep is 2 after 5 secs and power off. let go of button...repush power button(hold)...(beep)...then beep again after 5 secs...then 2 fast beeps...let go of power button. it will ask you to connect your USB to your controller then push the PS button on your controller. you should be in the menu for safe mode.(research your options there thru sony and understand what they are first before running them!)
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Will not turn on when I push the power button
This indicates the chair is in lock-out mode.
Use an XLR lock-out key or manually unlock the controller by holding the power button during the on cycle for 3 seconds, then push the joystick forward til it beeps, then pull it back until it beeps and then release it. You should be unlocked.
Sep 01, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
PS3 has no picture, have sound, holding power button doesn't fix
did you do the steps right, push and hold, the push is one beep and hold is one beep
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Kenmore Elite 45986 Front Load Washer Logo
145 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
