Question about Ricoh Office Equipment & Supplies
Model sp200s. What does c8 error indicate? - Ricoh Office Equipment & Supplies
    New Friend:
  • 33 Answers
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
Posted on May 03, 2016
    New Friend:
Ricoh sp 200s C1 error
Posted on Jan 03, 2017
I have a ricoh sp200s printer error c8 what is this solution
If you wish to get some details about printer Error codes; check the site linked here. Pull up older posts.
Nov 25, 2016 | Ricoh Office Equipment & Supplies
Red light of ricoh sp200 is parmanently on
Red light all time when ink is finished and refilled it.
Feb 25, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Jan 16, 2013 | Electrolux WT30H240DU Dishwasher
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this 21 of the pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact let me know if it isn't the right one and I'll go look some more. there another model number on the inside side of the washer door?
Jun 21, 2012 | Electrolux Dishwashers
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
Manual shows error 05 or 13:
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Code C8 76
Remove power source from the unit. If remote control is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
Restore power and see if unit functions normally.
Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support .
If this helps, please indicate so.
Aug 06, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
2,807 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
