Question about Xerox Phaser 3124 Printer
The red light turns on. what should i do?
It says it's a sistem error and i should call the service
My epson 1410 blinks 2 red light whwn i turn it on. Please help
If power button is on (not blinks) and two red lights are blinking alternatively it means the inkpads are end of life. Ask epson service centre to reset it and replace the ink pad. You can go for wic reset with fees.
If power button is blinking with two red lights, it means your printer cannot initialize. Its a fatal error. Ask epson service engineer to service it.
Oct 27, 2016 | Epson Office Equipment & Supplies
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
How to solve error c2551 in Konica bizhub c220
C 2557,C 2558 Black TCR sensor.
C 2551,C2552,C 2559 Cyan TCR sensor.Check de consumabile life,if you have possibility change the Black and Cyan Imaging unit.Enter in the service mode Press Utility key - Metercount- Details- Stop 00 Stop 01 select Sistem 1 or Sistem 2and read the messages.For reset turn OFF the copier,press and hold the Utility key turn ON the copier and then the display appaire Trouble reset release the Utility key and touch the reset,turn OFF the copier wait 2 minutes and turn ON.
Feb 07, 2013 | Konica Minolta bizhub C250 All-In-One...
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Hi, i have message appeared on dashboard volvo v50 2.0d 2005 "engine sistem service required", could you tell me what is that mean. thanks
Millage service message can be reset without dealer tools. However this is an error message. You need diagnostic tool to check the error code. All you can do right now is to enter hidden menu and check which module is reporting issue (DTC code).
Apr 25, 2011 | 2006 Volvo V50
I am having toruble with my imobiliser on my fiesta van 1.8td as it wont crank over and the red led light by the clock display flashes as normal with ignition off and as soon as i turn the igniton on the...
you have problem with the anti theft sistem of the vehicle and you wont be able to start your vehicle with that key. you can try to start the vehicle with the other key but if the anti theft light is flashing fast with both keys you will have to send the car to the dealer for service
Feb 13, 2011 | Ford Escort Cars & Trucks
Montana 2003 It is a red circle inside a brackit ( ) with a wave-like pattern on the bottom. The (!) and (P) lights also lite up with it
Your van thinks it has the parking brake on, or there's a problem with it. It could be something as simple as the switch, or a true problem with them.
Nov 19, 2009 | 2003 Pontiac Montana
1 red light on my xbox 360
Contact microsoft because its an error sign, unlike if it was 4 red lights.
0800- 587- 1102
that is the uk number
Good luck
Apr 23, 2009 | Microsoft Xbox 360™ Premium White Console
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Xerox Phaser  3124 Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
