Question about Canon Computers & Internet
Scan using canon irc3380 - Canon Computers & Internet
2 Suggested Answers
  • 92 Answers
SOURCE: How to set output of
hello, go additional function,next programming communications,next common TR, next send out file,choose file to pdf
Posted on Dec 22, 2008
How to adjust color irc3380i
http://www.copytechnet.com/forums/canon/67808-need-help-irc3380-correction-faulty-images.html
May 11, 2015 | Office Equipment & Supplies
heter lamp or fuse problem
May 22, 2014 | Office Equipment & Supplies
Canon irc3380
CCD week
Apr 24, 2013 | Cameras
How to set the default copy mode on a Canon irc3380 so that it starts up in black & white copy mode rather than color?
First adjust main screen as you want if to be (ie black and white mode). Once you have your default selected go to additional functions. Go to the copy selection and with in that list there is the section to save default settings. Now when you restart machine B/W and all other setting will be default. Good Luck
Jun 16, 2011 | Canon imageRUNNER C3380i Color Copier
I need canon irc 3100 scaner driver i connected printer but i cant scan
u can open canon india website and select your model no. and download the network scanning driver after download u can install your system and use photoshop for scanning, choose online scanning option in your zerox machine and scan through photoshop (click File-Import to canon network gear ver. 2.7. u can use feeder also while scanning
Dec 02, 2010 | Canon iRC3100 Printer
How can I correct error Code E602-0001 on my Canon copier?
You can try to reflash the hard drive or replace the hard drive
Sep 27, 2010 | Canon imageRUNNER C3200 Copier
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
I am suddenly getting 'check network connection' on irc3380. Its is linked with MAC via ethernet hub. Thanks Mike
Check that the cables are properly connected and that the port it is connected to is active. Then make sure that the IP address of the copier has not been issude to another device. Otherwise, the copier has lost it's network settings and will need to be re-entered.
Good Luck
Nov 06, 2009 | Canon Office Equipment & Supplies
How can i get paper to feed automatically without having to press the ok button on an canon irc3380?
actually u are printing from microsoft words or excell.1)pls check the paper size setting
2)check your paper size setting at printer driver page setup.
3)get the device status at printer driver advance setting.
Aug 05, 2009 | Canon Office Equipment & Supplies
How to set output of scanned docs to default to PDF format using Canon irc3380
Dec 21, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
