DSL NOT STANDING.
Dsl light in utstarcom wa3002g4 modem keeps blinking first slowly and then speedly as if connection is going to be made but then it stops and again starts blinking the same way as mentioned before ,does not stand still, and no connection be made , solution pl i have reset both way from switch below and by dialing 192.168.1.1 and making default setting and removing and adding makig new connectinon as per procudure. but in vain.
    Master:
  • 992 Answers
If you are having trouble with the modem, call your isp to get this trouble sorted out.
Posted on Jun 06, 2014
  • 5 Answers
SOURCE: fax config
Actually, you cannot send faxes through a DSL modem. You have to use a phone line or send it through the internet (not directly through the modem), at least from what I know...
Rgds.
Posted on Nov 10, 2007
ronenfe
  • 91 Answers
SOURCE: Medion pc keeps rebooting just as starting to load win xp home
sorry, my computer just hanged, we can continue the chat in skype, my username is : ronenfe.
or in messenger : ronenfe@netvision.net.il (this is also my email)
or in icq: 18300905.
Posted on Mar 15, 2008
bigbiggs
  • 326 Answers
SOURCE: I have tried to replace
Try contacting the DSL provider, if not All-Operatingsystems-Lost.
U may try Start-controlpanel-network connections-local area connection-properties
Ensure correct card under connect using.
click on configure.
click on advanced.
reset to auto detect
click ok
reboot
There are sometimes issues with the PPPOE. the DSL provider should be able to resolve this.
Good Surfing
Posted on Mar 16, 2008
Cytherian
  • 124 Answers
SOURCE: Unable to reset a Belkin Wireless N F5D8236-4v1 back to default
That is indeed strange. Holding in the reset button should definitely clear the wireless router memory. Are you sure that you're going to the right administration page to configure the router? It should be something like 192.168.1.1.
Also... by any chance are there other wireless networks nearby? I'm wondering if your computer accidentally connected to that while the wireless router was off... and now you're going to the wrong router.
If none of that works, try leaving the router unplugged for about five minutes. The volatile memory shouldn't last much longer than that.
Posted on Dec 24, 2008
sarasvatas
  • 329 Answers
SOURCE: orange light in power button on ... no blue
try resetting bios setting
Posted on Nov 21, 2009
Utstarcom modem
The blinking DSL indicator may be indicating a poor connection (wire) or a noisy line.
Apr 19, 2014 | Computers & Internet
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Utstarcom adsl modem router wa3002g4
check for the drivers first check power on router check all cables as well
Dec 02, 2013 | Computers & Internet
WA3002G4 Modem Wifi and Internet Light not on, DSL light is steady
make sure there is no noise on your line, lose connection....and call your internet provider, mabe is not activated properly.
Aug 27, 2012 | D-Link Computers & Internet
My modem is connecting problem,it will connect after five minits it will disconnect. modem model:utstarcom-wa3002g4
I have a link about how to configure it to Always On mode with ADSL as the connection technology from the ISP.
http://www.indiabroadband.net/bsnl-broadband/4545-configuring-utstarcom-wa3002g4.html
If you are using other technology there might be difference on the settings. You can contact your ISP to find out the technology they are using which your modem connects to. You can apply for an additional IP address to improve the performance of your connection too. Make sure you have a filter on every phone line if you are sharing the phone jack with your ADSL connection. Most of time they should have done that when they install the ADSL but just in case.
Aug 18, 2010 | Computers & Internet
I have type 4 utstarcom modem.my modem restarts now and then,dsl light goes on blinking and i loose net connection. is it the problem of modem?
hi....
this may be because
1.of the modem problem also
2.votage fluctuations.when the voltage comin to modem falls the modem gets off and when you get it right then it starts again.
3.the net gets connected only when the DSL light is glowing continously.As the modem switchs off and starts up again it takes time for the DSL light to glow continously.
if my answer was usefull to you please vote me
Jul 13, 2010 | Computers & Internet
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
Constantly blinking Activity light
Well, you are very correct with the activity light blinking and the increased blinking except the fact that modem will encounter a problem in future...
The 5 different lights on your modem namely Power, Ethernet, DSL, Internet and Activity have their own indications and explanations.
1. The Activity Light indicates the amount of activity that is takin place on the computer on the Internet though the activity might blink even when you are not browsing. This can be explained by stating that the computer constantly keep sending signals  about it being connected to the internet and any other acknowledgements..
So, you've got nothing worry about unless the Power or the Ethernet or the DSL or the Internet light Blinks....
Cause they are the resultants of a fried modem(check for the adapter), faulty LAN connections, interrupted Dsl line and the account verification failure indications respectively.....
Dec 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
David Payne
David Payne
