Question about Apple iPhone Smartphone
Cannot see the menu page when i press the home button
I cannot see the menu page when i press the home button. I bought a new iphone. I inserted the sim but didnot get any phone menu. but i can see the number pad..
  • Anonymous Mar 14, 2014
    phone is very slow to leave the page i am on. I have to press the home button several times
    Problem Solver:
  • 7 Answers
It needs to be activated by itunes
Posted on Jun 19, 2009
Iphone 4 network not available
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new after you can put your stuff back on with itunes all apps and contacts that have been saved to itunes. the phone lock the sim card that is installed first any other sim card will not work. do this and put you sim card in when it has updated the phone then it will add server settings. then you phone sim will add the messaging services after it has been on a while. if not go to the web page and request setting to be sent to phone you will need the phone number to do this.
Jan 23, 2013 | Apple iPhone4 4G iPhone 4
How do you take the sim card out of a i phone 3
First, if your iPhone is carrier locked (as most iPhones are), you can only use a SIM card from the same carrier -- if you purchased a subsidized iPhone from AT&T, you can only use SIM cards from AT&T, for example.
If your phone is in a case, remove the case. Power off your phone by pressing the power button for several seconds and confirming the power off operation when the on-screen prompt appears.
On the top of the phone, just to the right of the headphone jack, is a small hole. Gently insert an unfolded paper clip or a short piece of thin wire into the hole and press the SIM release button. The SIM tray should pop out. Carefully remove the SIM tray, replace the SIM card and re-insert the SIM tray.
Now you should be able to power your phone back on and use your new SIM card.
Apr 07, 2011 | Apple iPhone 3G Black Smartphone
I just bought a used iphone 2G or 3G not sure, updated it to ios 4 and now it says insert sim.. i did, but now it says connect to itunes. when i connect to titunes it says the iphone cant connect to itunes...
Make sure you have the latest version of itunes on your comp & power up comp & itunes
-power off your phone
-hold down the home button (around 6secs) then insert USB cable while still holding button then release button when cable plugged in
-itunes will then bring up message saying that the phone has been detected in recovery mode
- it will then give you choice to restore your iphone
-continue with this choice & restore your phone as a new iphone, this will wipe everything from the phone including the passcode. I have pasted a link below if you get confused with the restore
Hope this helps!!
Click here for restore info!
Jan 12, 2011 | Apple iPhone Smartphone
I am getting a "No SIM card Installed" message -
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2010 | Apple iPhone Smartphone
I bought a new Xperia X10 and i want to copy contacts from my old phone. I copied all my contacts from old phone to the Sim. My question is how can i copy the contacts from Sim to my new X10?
Yes indeed you can copy your sim contacts to your X10
Just insert the sim into your x10.
Turn on the handset
Open main menu by tapping bottom of screen. Or touch bottom of screen and drag finger upwards.
Find "phonebook" and tap that.
Now your phone book is open Press the Bottom LEFT button on your handset not the screen the actual button.
A menu will pop-up so tap the "More" option
Then tap "Import Contacts" from this menu
Then tap "Sim Card" from the new pop-up.
The rest should work for you.
I hope this helps and I hope you enjoy your new phone. :)
Jul 18, 2010 | Sony Ericsson XPERIA X10 Cell Phone
My i phone say..please insert your sim card..
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 26, 2009 | Apple iPhone Smartphone
My phone used to work well. I just turned off my phone and when I opened it there was no signal as well as no carrier menu in settings.I reset my phone it didn't work at all. Any solution
There are 4 different reset to try:
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Apple iPhone 3G
My iphone can't recognize thr sim card
remove and re-insert the SIM card when the iphone is off. then, hold the home button while turning the phone on.
Apr 09, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
79 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
