Question about Garden
Ryobi strimmer My Ryobi RPH26E Expandit strimmer 'dies' on full throttle. New strimmer used only for a hour or so. so far.
scrodamoon
  • 659 Answers
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
Posted on Oct 04, 2008
boscia
  • 163 Answers
SOURCE: ryobi cs30 rope problem
try removing the starter housing, inside will be a large white or black wheel, visually inspect to make sure the componets are not damaged and that nothing jamming it. try using a lithium spray grease to lubricate the componets. if it still doesn't work the inner coil is probably damaged or came off track. it is very difficult to fix or replace this coil. i suggest taking to your nearest service center but if you would like to try it yourself, let me know and i will give you further instructions.
Posted on Nov 29, 2008
  • 37 Answers
SOURCE: Ryobi model RCT2800B grass strimmer will not start
close your carb adjustment screw a bunch of turns... yours may even be missing.
Posted on Apr 19, 2009
  • 57 Answers
SOURCE: Stops when given full throttle
Most likely carburetor needs adjustment.
Posted on May 15, 2009
#1 Taper
  • 1040 Answers
SOURCE: Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
Posted on May 29, 2009
Brand new Ryobi 2-cycle backpack leaf blower. It will not run full throttle. Should I take back and get new one or ?
Take it back. If the new one doesn't perform like it should get your money back and buy a Stihl. They will fuel and run the machine before you ever leave the dealer with it to make sure it runs like it should and they can answer any questions and even get you parts. Husqvarna may do the same thing
Nov 20, 2014 | Ryobi Garden
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Strimmer will not start got spark & fuel ryobi rbc30sbt
its probabley your throttle cable , try pulling the throttle full on when you starting up the trimmer word of warning though only do this on a very flat surface..
Nov 23, 2010 | Ryobi Garden
My Ryobi 705r strimmer won't run !
The carburetor needs to be disassembled and cleaned with carb. cleaner. Or, it needs a new carburetor kit. If you need tips on how to do this, just let me know.
Jim
Jun 03, 2009 | Ryobi Garden
Apr 19, 2009 | Ryobi Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
