Question about Dell OptiPlex Computers & Internet
Dell OptiPlex 780 fan making rattling sound
Fan making rattling sound
    Master:
  • 569 Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Posted on Nov 16, 2008
  • 8 Answers
SOURCE: dell optiplex gx280 makes loud fan sound at
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Posted on Jun 12, 2009
Geekman
  • 32281 Answers
SOURCE: Dell optiplex 780 shutdown automaticaly
The desktop could be overheating and shutting down.
To fix this problem, please click on this link :-
Posted on Apr 14, 2011
  • 26 Answers
SOURCE: internal speaker sound is not
Mr. Dev
Its the fault from the motherboard but i can help you
Please change the front panel's whole audio connector for the same after that issue will resolved..
Thanks ]
Dhiren Motivaras
Posted on Sep 16, 2011
bronk50
  • 27725 Answers
SOURCE: I HAVE DELL OPTIPLEX 780 DESK TOP WORKSTATION ,THE CD DRIVE IS NOT SHOWN WHEN I OPEN IT
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they could be faulty ?
you might have to physically unplug the cd/dvd drive restart your computer this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Posted on Mar 14, 2012
HVAC is making rattling noise
Your fan that is attached to your blowermotor is loose, causing the rattle, or the bearings in your blower motor are bad, causing the shaft and fan both to rattle.
Dec 12, 2013 | 2005 Pontiac Grand Am
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
My televiosion hs a rattling sound, it displays cooling fan 2 but the sound goes away after a short period of time. I have had a repairman out but the problem still isnt fixed after tow visits
Hi.
The rattling sound is usually coming from one of the internal fans. The fan may make noise because one of the blades is broken, because of dust or foreign objects in the fan or because of a defective fan bearing. If the noise goes out after a while then the problem is likely a defective fan bearing. If display is indicating that there is a problem with fan 2 then fan 2 must be replaced even if at the moment of testing is not making noise.
Regards.
Ginko
Sep 10, 2011 | Samsung Televison & Video
My jeep is making a rattling noise in the front by the grill. What could this be? Someone said it might be my blower?
It could be something as simple as the fan blades rubbing up against the fan shroud or it could be the idler pulley bearings going bad and making a distinct rattling sound. I've seen them rattle till they break off, releasing the engine belts and stranding the vehicle. Have them checked out to see if they have bearing play, are worn and maybe need replacing.
Dec 13, 2010 | 1996 Jeep Grand Cherokee
My computer when turned on is making a big rattling sound. What is wrong with the computer and how can I fix it?
Sounds like something is loose and is hitting the fan blades.
Remove the cover and check the cables near the fan, tie the cables back and make sure they don't hit the fan blades.
Sep 20, 2010 | Computers & Internet
Carrier furnace clicking/rattling
Hi some thing in the blower motor or combustion fan?
Feb 16, 2010 | Heating & Cooling
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Rattle and Gurgling noises
It's the fan bouncing off the fan-motor housing. The best way to stop this is to shim the motor mount so the fan will ride with the motor shaft "out" preventing it from bouncing. When you raise the fridge on one corner you are doing the same thing the shim will accomplish.
The draining gurgling sound is probaby freezer defrost water being pushed down the drain tube into the drip pan at the bottom. The door action pushes/pulls air in the tube and pushes out water.
May 27, 2009 | Refrigerators
Fan making a rattling sound
check whether any wire is touching it or the blades touches the outer circumference in someway...
Sep 27, 2008 | Toshiba (P000247220) Fan Assembly
Computers & Internet Logo
54 people viewed this question
Alun Cox
