Question about Dell OptiPlex 780 PC Desktop
Rattling loud fan dell optipilex 780
Fan not running when purchased 2nd hand have a press F1 key to boot because fan not running after starting finally got it going somehow after running a Dell diagnostic tool on a re-boot the fan came on with a rattling sound. sound
  • Official Brand Answer
  • 560 Answers
Anonymous,
You may want to replace the fan. You can call the Dell Spare Parts Department at 1-877-717-3355 to purchase a fan.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jun 04, 2015
squipps
  • 204 Answers
SOURCE: CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Posted on Feb 07, 2008
antiochpc
  • 1314 Answers
SOURCE: Hello
Yes, you need to replace that fan and not run your computer without it working because it can cause it to overheat and then you'll have to replace a lot more than just a fan. Open up the side of your computer and see which fan is not moving when the computer is turned on but it will be the one attached to the card cage :c)
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: dell optiplex gx280 makes loud fan sound at
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Posted on Jun 12, 2009
  • 212 Answers
SOURCE: Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Posted on Jul 01, 2009
SOURCE: Dell Demension runs great but loud fan noise that
I had a similar problem with excessive fan noise on my Dell Dimension 5150. The solution was to replace the worn heat sync compound that was between the cpu and the heat sync itself. (£0.99 ebay)
Posted on Aug 16, 2009
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Making rattling sound Dell OptiPlex 780
It could be a fan making the noise. Either a fan is going bad, possibly a bearing or bushing. It could just be a wire that got too close to a fan and the blade hits the wire.
Apr 20, 2014 | Dell OptiPlex Computers & Internet
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
A message says "previous fan
my dell gx 280 fan failure how i solve it'
Nov 23, 2010 | Dell OptiPlex GX280 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
Computer fan is to loud
Do the following:
Reboot your computer.
As it reboots, press the F1 key
When it goes into your bios, look through there until you see a page that allows you to control the fan speed.
change the fan to run more slowly.
Press F10 to save and Exit.
Nov 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Dell OptiPlex 780 PC Desktop Logo
171 people viewed this question
Alun Cox
