Question about Health & Beauty
Lambretta rear wheel locked up - Health & Beauty
2 Suggested Answers
miss tme
SOURCE: my lambretta back wheel locked while riding and wont start ,li125
There is very little information in the question. Description of other symptoms are needed to go further with this.
Did the back wheel free itself when a) in neutral or b) when in gear? Is the engine seized? Does the engine kick over easily with the plug out? Does it look like the plug has particles of Aluminium on the end? How long did the strange noise last before the back wheel locked? How fast was the engine revving just before it failed?
Posted on Oct 05, 2009
I have a lambretta li 150 I have had a125 engine fitted and want to register as a 125 what do I need to do
On your V5 fill out the modifications, post it off to DVLC, Swansea SA99 1BD then tell your insurance company otherwise you are no longer insured.
Apr 02, 2017 | Lambretta Motorcycles
I have a SYM Joyride 200. it has a jerking motion or shakes when accelerating or at low speeds. belt, rollers and gear oil were all replaced. the mechanic I went to said its normal due to wheel clearance....
One these girly things with no gears so yet it will jerk a bit ,get a proper scooter like a vespa with manual box like or a sx 200 lambretta ,or better still get bigger wheels which are safer and get a nice cruiser style motor bike
Nov 29, 2013 | Cars & Trucks
Wheels keep coming off
1 - Remove rear wheel
2 - Remove posi screw from bottom of rear wheel hub assembly
3 - Allow bottom block and spring to fall into palm of hand
4 - Push rear wheel lock bottom down through rear assembly to remove.
5 - Clean wheel lock button and locking plate to ensure free movement.
6 - Clean rear hub and locking button housing with dry cloth.
7 - Apply lubricant thinly in recess to allow free movement of button (dry Teflon spray is best - find it in the laundry aisle of larger supermarkets)
8 - Re-fitting is reverse procedure of removal instructions.
Nov 30, 2011 | Quinny ZAPP Stroller
Rear wheel will not rotate after spinning on snow/ice
rock the car to brake them free the brakes are locked up
Feb 11, 2010 | Buick LeSabre Cars & Trucks
1991 eagle talon tsi awd back wheels lock up
I'll assume this is a manual 5peed. The transmission (a W5M33) has a viscous coupler (VC) inside that is linked to the transfer case shaft. This in turn connects to the prop shaft to the rear diff. The rear diff (for the TSi) is usually also viscous coupler to provide a limited slip (LS) function. So ... what can cause the rear wheel lock up? If the W5M33 VC breaks (unusual but not impossible), you'd probably still have rear wheel spin. If the transfer case brakes (quite common with hard use), it could lock up, locking the rear wheels. The W5M33 VC then would overheat. A VC is filled with silicon that smells vile when heated. Best case, you'll have to pull the transfer case off and inspect it. Worst case, pull the whole transmission out. If all is OK with the wheels off the ground and a rear LS, spin one rear wheel and the other does the same. On the front, no LS function, and one wheel will spin. Look at lancerproject.ca for more info on AWD transmissions.
Feb 01, 2018 | 2000 Eagle Premier
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
