Question about Apple iPod HiFi System (M9867ZA) Docking Station
Liteon power supply pa 3150 01a - Apple iPod HiFi System (M9867ZA) Docking Station
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
HI I HAVE SEVERAL LITEON POWER SUPPLYS MODEL NO. PA-1201-1 THAT HAVE WENT DEAD. IT SEEM THAT THIS POWER SUPPLY FAILS ALOT. I WAS WONDERING IF THERE WAS SOME WAY I COULD FIX THE UNITS THAT I HAVE. DO YOU...
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
May 12, 2011 | Lite On Computers & Internet
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Mar 03, 2010 | Computers & Internet
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Hi my acer aspire 4315-2490 power cord is malfunctioning and it is not supplying power to the laptop. What power cord models can I buy to replace or is it fixable?
Let me give you a exact model number that will work or you can stop at a best buy and pruchase a universal "expensive" or go direct to acer for this part number its a liteon PA-1650-02. that is the exact one you need for you laptop. Thanks
Aug 10, 2009 | Acer Aspire 4315-2490 Notebook
Cable/Transformer for Quantum Server 1000
I've got the same Snap Server 1000 and lost the supply some time ago - I found a LiteOn monitor supply model PA-1400-02 does the trick and fits exactly.
Spec is 3.33A 12Volts DC out, positive inner, negative outer.
Hope that helps.
Jan 19, 2009 | Quantum Snap Server 1000 (5325301081) 10...
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Apple iPod HiFi System (M9867ZA) Docking Station Logo
434 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
