Question about Poulan Pro " Pro" Self Propelled Mower
Murray 8/30 rideon mower
Loss of all drive sounds like a gear is stripped.
2 Suggested Answers
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
Hi what is the size of the deck belt for a john deere d100 rideon mower thanks
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 08, 2016 | John Deere D100 42 in. 17.5 HP Gear Drive...
I have a Murray lawnmore and it won't go into gear
Is the lever to disengage the drive actuated? This is a common thing that can happen, which opens bypass systems for the transmission, so the mower can be pushed around by hand.
Aug 29, 2016 | Murray Garden
Starter gear strips after a couple times of starting on a 20hp briggs&stratton engine on a Murray lawnmower
bad compression release valve do a valve job and put in new valves or crank bearings bad do short block better just by new engine save the head ach with the motor valve job 100.00 per cylinder short block 300.00 or 400.00 plus 150.00 to put to gether best buy new tractor
Sep 11, 2014 | Murray Garden
12.5 hp Briggs and Staton Murray 42 in cut will not move and smoked when put in gear
check the tension of the drive belt sounds like the belt is slipping also check it for oil if you have a oil leak and the oil got on the belt that will make it slip as well
Jul 06, 2012 | Murray Garden
Murry 10hp 8/30 rideon can select gears but wont engage
inspect the drive belt from the engine
Jun 30, 2012 | Garden
My murray riding mower wont go in to gear ???
If you can select gears when the motors not running but not when it is then your drive belt is dragging.(trying to drive even when the clutch down).This is usually the belt guides not holding the belt in a neat loop off the pulleys front and back when the clutch is down.
Jan 31, 2012 | Murray Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Starter motor on rideon mower keeps snaping plaste gears
Use OEM Briggs & Stratton gear specifically for your model number engine and be sure you install the gear with the bevelled edges of the teeth UP
Sep 09, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Poulan Pro " Pro" Self Propelled Mower Logo
15 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
