Question about Ricoh Office Equipment & Supplies
Error 2105 sc101, how could i reset this - Ricoh Office Equipment & Supplies
3 Suggested Answers
  • 5 Answers
SOURCE: ERROR CODE SC101
Definition Symptom Possible Cause
SC101 Exposure Lamp Error
The scanner has scanned the white
plate, but cannot detect the white level.
• Defective exposure lamp
• Defective exposure lamp stabilizer
• Defective exposure lamp connector
• Unclean scanner mirror
• Scanner mirror out of position
• Defective SBU board
• Defective SBU connector
• Lens block out of position
• Incorrect position or width of white
plate scanning (�� SP4-015
Posted on Mar 14, 2009
SOURCE: error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Posted on Jun 11, 2009
My aficio 1022 is showing code sc101. How can I fix it
SC101 is scanner home position error. Check the sensors or the white plate, usually its dirty.
Aug 13, 2014 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh photocopier 1055 code sc101
for sc101
Exposure lamp error
white plate.
Dec 08, 2012 | Ricoh Aficio 1013F Copier
Functional problem sc101
SC101 is an exposure problem.check if at on of the machine exposure lamp is light in a few sec. then off then follow this as a guide
SC101 D Exposure LampError At trigger on, thelamp was not detected on. Exposure lampdefective Lamp regulatordefective Exposure lampconnector defective Dirty standard whiteplate Dirty scanner mirroror scanner mirror out of position SBU board defective SBU connectordefective IPU defective
Aug 28, 2011 | Ricoh Aficio 450 Copier
Sc101-00
just check the exposure lamp maybe busted
Jan 05, 2010 | Ricoh Aficio 450 Copier
No power
reset the unit... pin hole is in the back of the sc101. If the green light has never been on, you have a dead duck / DOA. Either the Power supply or SC101 box (or both) is defect. Contact to the Vendor from where you purchased it.
Dec 21, 2009 | D-Link DI-704P Router
Error SC101 on copier
Jun 10, 2009 | Lanier Office Equipment & Supplies
Error e014-0003 on canon irc 2105
check ther heter unit are the heter motor is ok
Jun 05, 2009 | Canon Office Equipment & Supplies
I have one copiar machin 5455 my problam is stating machin showing error sc101 .
Sc101 is a scanner home sensor error. Try removing the exposure glass, and clean the WHITE STRIP on the underside of the glass. If that does not work, there is a mechanical problem with the scanner such as a broken drive cable, which will require a trained technician to repair.
May 03, 2009 | Office Equipment & Supplies
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
