Question about Garden
Murray 8 30 manual
Loss of all drive noise sounds like a gear stripped on my murray 8/30 rideon mower any hints Richard
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
  • 496 Answers
SOURCE: Replacing the self-propelled belt on my Murray mower
Here is the link to the parts list for your mower. Though it doesn't give instruction for replacement, it does show an exploded view of the components:
http://www.outdoordistributors.com/pdf/Murray/MURRAY-MODEL-22646X92A-WALK-BEHIND-MOWER-(1999)-PARTS-LIST.pdf
I hope this helps...
Good luck
Posted on Aug 26, 2009
  • 93 Answers
SOURCE: murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Posted on Sep 15, 2009
mowerman1857
  • 389 Answers
SOURCE: starter motor on rideon mower keeps snaping plaste
Use OEM Briggs & Stratton gear specifically for your model number engine and be sure you install the gear with the bevelled edges of the teeth UP
Posted on Sep 16, 2009
SOURCE: Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Posted on Apr 29, 2010
Hi what is the size of the deck belt for a john deere d100 rideon mower thanks
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 08, 2016 | John Deere D100 42 in. 17.5 HP Gear Drive...
I have a Murray lawnmore and it won't go into gear
Is the lever to disengage the drive actuated? This is a common thing that can happen, which opens bypass systems for the transmission, so the mower can be pushed around by hand.
Aug 29, 2016 | Murray Garden
Starter gear strips after a couple times of starting on a 20hp briggs&stratton engine on a Murray lawnmower
bad compression release valve do a valve job and put in new valves or crank bearings bad do short block better just by new engine save the head ach with the motor valve job 100.00 per cylinder short block 300.00 or 400.00 plus 150.00 to put to gether best buy new tractor
Sep 11, 2014 | Murray Garden
Riding mower makes fast loud whirring noise and wont start
Starter bendix is bad, starter is turning, causing the whirring sound, but bad bendix isn't pushing the gear up to mesh with the flywheel teeth. Repair bendix or replace starter.
Jul 30, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
My murray riding mower wont go in to gear ???
If you can select gears when the motors not running but not when it is then your drive belt is dragging.(trying to drive even when the clutch down).This is usually the belt guides not holding the belt in a neat loop off the pulleys front and back when the clutch is down.
Jan 31, 2012 | Murray Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
