Question about Husqvarna Sewing Machines
Wheels not working - Husqvarna Sewing Machines
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Which models? Suggest checking the user manual. Manuals can be viewed, downloaded, or printed at http://www.manuals.husqvarnaviking.com
If it is the hand wheel, it may be that the belt has come off.
Posted on Oct 16, 2014
I have a Necchi 3101FA. I am trying to figure out how to release the stop motion knob so that the needle won't run while I am trying to thread the bobbin. Does anyone have any idea?
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Aug 26, 2015 | Necchi 3101 Mechanical Sewing Machine
Hot to tighten both wheels to enable to sew
Sewing machines do not have 2 wheels
Nov 09, 2014 | Sewing Machines
Machine wheel is very tight and hard to turn
not knowing your machine make or model, I can only suggest that you are having "tension" issues. Most machines have tension control located around the wheel, sort of like a second very thin wheel. This type usually requires that you would hold the wheel in place while moving the 2nd wheel to make the adjustment.
Other machines have the tension control looking like a push button. Maybe in the middle of one of the other tenstion wheels. pushing that button in while turning that and/or other control wheels would help that.
I may also be that your machine just needs to be oiled. Fabric stores will have this oil and it is specially formulated for sewing machine parts. More is less w this type of oil.
T ake a look all around and even under the machine, hopefully you will find a number for tech support for your machine.
Good Luck and Happy Sewing!
Jun 05, 2012 | Sewing Machines
Singer Quantum XL-100 Sewing machine can not see the stitch selection, but it lights up
the machine may need to be check to see if there is something wrong with the computer part of the machine
May 28, 2012 | Singer Sewing Machines
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
I need to take apart my Brother XR-52 sewing maching to replace the spool pin. I have removed all the screws and cannot figure out how the case comes apart. Thank you.
XR-52 (and probably similar) has 9 screws on the back and bottom that needto be undone - be sure to keep track of which screw goes where becausethey're almost all different. One other screw is under the "nose" piece which holds the front shell to the back - it just needs to be loosened. After you haveremoved the 9 screws and loosened the one I mentioned you start at the bottom and pry apart carefully of course, noticing that the last part comes apart at the top where the three wheels go thru the back shell. In order to take off the front shell you need to remove two more screws, also fairly obvious. Reassembly is opposite order being sure when you get ready to put the back on that you align the three wheels at the top first, then work down to the bottom, replacing all the screws. That's really it - not rocked science. Just be sure not to over-tighten screws going into plastic. Have fun!
Feb 27, 2011 | Brother Sewing Machines
Needle is getting stuck on the bobbin case
That usually means there is a problem with the threading. If the thread is pulled through the wrong side of the needle, is wrapped around the top wheels wrong, or the bobbin is threaded wrong, this will usually cause it to jam up by the bobbin. i would suggest re-threading your machine, or if that doesn't work, contacting the problem hotline.
Oct 15, 2009 | Brother CS-100-T Computerized Sewing...
Bottom tread keeps jamming and getting all knoted up. The display gives me an E6 error code. what can i do
try re-threading your machine. usually when the machine is jammed at the bobbin or when the needle gets stuck to the bobbin thread, it means that there is an error with the thread. make sure that the thread isn't pulled through the wrong side of the needle, wrapped the wrong way around the wheels on the top, and that the bobbin is threaded correctly. if this doesn't work, you may want to contact their hotline.
Sep 23, 2009 | Brother CS-100-T Computerized Sewing...
Toyota SL3404D differential overlock
Please i am in need of an instruction manuel for the Toyota SL3404D
Apr 28, 2009 | Toyota TL-432DE Mechanical Sewing Machine
Thread breaking
On top of each of the wheels is a circlip. Remove the clips carefully (they will spring off) Remove the rubber wheels, remove thread lint etc. Replace wheels and clips. It the wheels appear to have developed a groove where the thread runs rplace the wheels. They can be purchased from an authorized Babylock dealer.
Jul 24, 2008 | Baby Lock Esante
Sewing Machines Logo
15 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
