Question about Lennox Healthy Climate HCWB3-17A Humidifier with Automatic Control
Summer setting on manual humidifier knob - Lennox Healthy Climate HCWB3-17A Humidifier with Automatic Control
Why does it have a different knob than listed?
New knob. Old manual. Someone forgot to update it when the new knob was installed.
Mar 05, 2016 | Holmes Products HM5125 Humidifier
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
We noticed the humidity went down to 30% and I adjusted the rate to increase Now our Aprilaire 400 says to change the filter. I did that, and it still says to change the filter. The furnace runs fine....
If your humidifier is equipped with a Digital Humidifier Control with Water
Panel change indicator, after replacing the Water Panel, turn the control
knob to the "Test/Reset" position until the "Humidifier On" light blinks to
reset its timer. (Blower must be operating and HVAC calling for heat.) Be sure
to turn the control knob back to it's original setting. If the "Humidifier On"
light continues to blink, your humidifier is in Test mode. DO NOT LEAVE THE
CONTROL IN TEST MODE OR HUMIDIFIER WILL NOT OPERATE.
Jan 27, 2011 | Aprilaire 400 Humidifier
The humidstat light is on when I first try to get humidifier going.
This is normal, based on where you have the humidistat knob set to, it will go out only after reaching the humidity level set on the knob. Also if you have it setting in a fairly large open area of your home, it may take a loooong time to reach the proper humidity level. My cousin has one of these units setting in his living room, which has a cathedral ceiling, the unit's humidistat light never goes off, and the unit runs continually, unless the resevoir runs low. But the unit operates fine.
Hope this answers your question. You may refer to your user's manual regarding this, or if you don't have a copy, you may download one at this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
kcomp1863
Nov 30, 2010 | Honeywell Warm Mist HWM-2030 Humidifier
How to change from summer to winter
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Sep 28, 2010 | Aprilaire 600 Humidifier
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
How to adjust settings
You can get a PDF version of the manual here...
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/dh835.html
Mar 16, 2010 | Honeywell DH835 Humidifier
Water drips from unit
lift the frontup2 inches should drain out back if not blocked
thumbs up
Aug 17, 2009 | Aprilaire 600 Humidifier
We have an old Aprilaire humidifier (Manual adjust)and having problems trying to figure out how to shut it off-for the summer.
close the by pass air flow valve. shut off the water supply and finally flow the thermostat wire to the transformer or the controller and shut off or disconnect. Unit should be serviced before winter. Cell may need to be replaced
Aug 10, 2009 | Aprilaire 550 Humidifier
Where is on/off switch HCM-305T-CST
There is a 0 setting on the fan speed setting knob ...
Dec 20, 2008 | Honeywell : Cool Moisture Humidifier...
Lennox Healthy Climate HCWB3-17A Humidifier with Automatic Control Logo
82 people viewed this question
Top Lennox Humidifiers Experts
Paul Carew
Dennis
Are you a Lennox Humidifier Expert? Answer questions, earn points and help others
