Question about Ricoh 6513 Copier
Nashuatec aficio sc 450 - Ricoh 6513 Copier
drichards
  • 87 Answers
SOURCE: aficio 450
SC 322 is a laser diode problem. It will require service.
Posted on Mar 28, 2008
  • 64 Answers
SOURCE: Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
Posted on May 26, 2008
  • 19 Answers
SOURCE: i have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Posted on Dec 24, 2008
Soulvisitor
  • 1113 Answers
SOURCE: My Aficio 4006 says SC 450
SC450 Paper Transfer Bias Current Leak
There is a charge placed on back of paper as it exits the drum, it is placed on the back of the paper via a charge roller/carona or sometimes a bar of little teeth ie VVVV....its job is to make the now formed pic on the drum come away and be attracted to the paper
This charge is not traveling along the intended path, check the bed are is clean and check the transfer/seperation carona, make sure it and the grid is clean and the wire is intact and not shorting at either end block to frame.
Posted on Nov 07, 2009
Testimonial: "Pretty helpful - I investigated further and the 4006 has a paper transport section with a corona and the little spring was rusty. Thanks for the help"
SOURCE: error code sc 306 aficio 1022
code 306 is not exist.
Try pressing. and # for more than 10 seconds.
He is not recommendable if you is not a technicians but Lost by lost this restores software. So that later it is necessary to make adjustments since the copier returns to values of factory.
Posted on Nov 14, 2009
How to clear error code sc 541 on ricoh aficio 2015
i want to make my nashuatec mp 500 copier to be dip in printig
Oct 04, 2012 | Ricoh Aficio 2015 Copier
Meaning ofSC 400 Nashuatec C2030 aficio
Nashuatec is made by Ricoh.. SC400 means that there is a problem with the fixing unit.
Jun 08, 2012 | Office Equipment & Supplies
Sc550
That service code SC550 normaly is a fuser web end error, you must replace the web and reset the % in 1.902 to "0". But i dont think the Ricoh aficio 450 have a fuser web. does this SC550 coming from your Aficio 450?
Sep 18, 2011 | Ricoh Aficio 450 Copier
Printer Nashuatec Aficio dsm651 I want software
user tools>system settings>admin> address book then select the user and you can scroll down or goto authentication and change the password.
if you cant get into admin try the username administrator with no passowrd or service with no passwrd
Jul 28, 2011 | Ricoh Aficio 450 Copier
Aficio 450 Copier: what is the meaning of sc 670 on 1035 machine...
DEFECTIVE BICU PWB OR DEFECTIVE CONTROLLER PWB THIS IS GOING TO BE EXPENSIVE 1000.00 OR MORE
May 17, 2010 | Ricoh Aficio 450 Copier
I HAVE A PROBLEM WITH MY COPIER,NASHUATEC D435.
Enter in the service mode(SPmode),open the front cover and turn OFF the copier.Unpluged the machine,wait 10sec.amd pluged ON.Before clean the thermistors and thermofuses in the image fusing unit.Close the front door and turn ON the copiers.
Feb 08, 2010 | Ricoh Aficio 450 Copier
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Aficio 450
Mar 27, 2008 | Ricoh Aficio 450 Copier
Ricoh 6513 Copier Logo
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
