Question about Ovens
Lamona HJA 3400 fan oven has developed a loud whirring sound once oven has warmed up,my oven works ok
My oven is just over 2 years old and works all ok,this noise has just happened
SOURCE: Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
Posted on May 16, 2008
SOURCE: Noisy Oven when heating up & fan spinning
i have a b600 oven and we've replaced the element but it's still not working can you help biskittin@hotmail.co.uk
Posted on Feb 02, 2009
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Posted on Dec 02, 2009
Testimonial: "Thank you for that. It's noisy even when the fan inside the oven isn't running (ie, just on convection) so guess that means it's the external fan?"
Where can i buy a new outer glass for HJA4610 Lamona as mine has exploded?
Have a look at https://www.howdens.com/appliance-collection/ovens/lamona-double-fan-oven/
Oct 07, 2016 | Ovens
How do you remove and adjust the oven door to sit squarely on the rubber seal Its a Lamona HJA 3220
open door half way,pull out on the door,it will slide off the hinges
May 09, 2015 | Ovens
Got a fan assisted oven Lamona 3400 in operation back heats up front dont?
does it use different elements for back and front? check for continuity. is fan working properly?
Mar 10, 2015 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Model HJA 3220 removal of internal glass panel
i have the manual if any one needs it... can't upload it here but email me if you want... faisal at citydealestates dot com - no spaces. covers HJA3220 HJA3320 and HJA3212
Feb 18, 2012 | Ovens
FAN NOISE in convection mode, as in a loud whirring sound, suggesting a problem with the fan. Any one else experiencing this?
FAN NOISE IS NORMAL BUT IF ITS SQUEELING THERE IS A PROBLEM WITH THE COOLING FAN. YOU DO HAVVE TO REMOVE THE OVEN FROM THE WALL TO REPLACE.
Jan 24, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven fire, loud explosion sounding like a welding torch,flames. Very nervous!
Most likely an element burning out though it does sound a little more excessive than is the usual case. Was the fan oven on, in which case remoce the inner ear panel in the oven and check to see if the element surrounding the fan has burnt out
Oct 21, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
