Question about Sigma Sport BC 1009 STS Wireless Computer
Mph won't stop flashing - Sigma Sport BC 1009 STS Wireless Computer
Trans won't shift only manually 6 cyl also won't go over 40 mph. 2002 hyundai santa fe
this sounds like a timing belt problem.
http://www.youtube.com/watch?v=nyB6syDyP0o
This is what could happen if not replaced.
Mar 07, 2013 | 2001 Hyundai Santa Fe
2006 Crown Victoria won't go over 40 mph
What have you checked so far ?
Fuel pressure ?
Exhaust restrictions ?
Jan 31, 2013 | 2006 Ford Crown Victoria
1988 ford taurus wagon chimes everytime i go 45+ mph and the speed light flashes... what's wrong?
You probably have the speed reminder set to 45mph. It chimes & flashes to let you know you are speeding. It will tell you how to adjust it in your owners manual. If you don't like it set it high eg: 100mph. then it won't happen.
Jun 02, 2012 | 1988 Ford Taurus
My 1995 suburban won't go faster than 25-30 mph even with foot to floor,service engine light on
im having the same problem did you ever find the solution , i was driving on the high way and it just stopped going fast and was hard to get it to go past 30 mph
May 30, 2012 | 1995 GMC Suburban
My bush tv won't stop flashing
The tv need service. Contact any experienced service technician.
May 07, 2012 | Bush 1433GRN2 14" TV
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
Engine stalls at 30mph upon hitting accellerator, then coasts to a stop. then won't restart. starter works, engine turns over, but won't fire up. next morning car starts fine. next week...
you may have to check the fuel pump function for pressure and volume when this happens as it could be a bad pump,you could have it checked when working as it could show up something but more likely should be done when it stops running.
May 19, 2011 | Ford Crown Victoria Cars & Trucks
I have a 2005 ford expedition and this morning while I was accelerating onto the interstate it started to sputter or **** between 60 and 70 mph. It stopped once I hit 70 mph but then my yellow engine...
the flashing light means you have a miss fire in the engine. You probably have a coil bad. Each cylinder has its own coil. My suggestion would be to go to a parts store and let them scan to tell you which cylinder, then change the coil. If thats not it then you have a bad injector
May 04, 2011 | Ford Expedition Cars & Trucks
Sigma Sport BC 1009 STS Wireless Computer Logo
154 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
