Question about Husqvarna Sewing Machines
Machine needle keeps breaking of my husqvarna h-class
yeroc
  • 397 Answers
SOURCE: needle keeps hitting the plate and breaking
possibly off timing,
Posted on Jan 21, 2008
bilabon
  • 46 Answers
SOURCE: needle keeps breaking the top thread...
In general, there are three main causes for this...
wrong needles (Singer), low quality thread (dual duty or all purpose), incorrect threading. Be sure to thread the needle from front to back.
Posted on Sep 02, 2008
SOURCE: bernina 2500DCET serger keeps breaking the centre
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Posted on Mar 02, 2009
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
lintalks71
  • 7 Answers
SOURCE: Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
Posted on Jun 19, 2009
Husqvarna #1+ sewing machine, is breaking needles under throat plate
This could be bad timing, or the needle is not in properly.
Make sure that the needle is pushed up all the way, and in the correct position. If the needle is too low, it will break.
Also, keep the bobbin case door open to see where the needle is catching.
Apr 10, 2013 | Husqvarna Sewing Machines
Thread keeps breaking using husqvarna
try these suggestions
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 30, 2012 | Husqvarna Sewing Machines
Has anyone had an issue with the husqvarna 600e continuously breaking needles?
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. machine could also be out of time
Aug 29, 2012 | Husqvarna Viking 1
check to see if there are any burrs in that area
May 24, 2012 | Husqvarna Sewing Machines
Designer 1 se needles keep breaking
Needle breaks
Feb 09, 2012 | Husqvarna Designer I
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
The needle keeps breaking.
make sure the needle is set to the correct position
Jan 27, 2009 | Husqvarna Freesia 415
DESIGNER SE breaking needles
Sounds like the needle to hook gap needs to be adjusted, i.e. the needle is striking the hook when in the lower position. As the needle becomes dull, it probably bends slightly causing more contact and hence breaking. I would try another dealer if you think that might help., You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 16, 2008 | Husqvarna Designer I
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
