Question about Panasonic Microwave Ovens
Bulb how to replace bulb in Microwave NN-K358CB
    New Friend:
    Problem Solver:
  • 15 Answers
Open the unit by removing the appliance security screws. you will see one or 2 screw holding the light bulb,
Posted on Jun 15, 2014
  • 833 Answers
SOURCE: panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Posted on Dec 17, 2007
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I need to find a
Generic replacement bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If you would prefer to order the original bulb, the best place to order Panasonic parts is Tritronics.
You can also call them at 866-779-5835.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
SOURCE: Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Posted on Jul 05, 2009
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
How does one replace the light bulb in the Panasonic NN-T990SA countertop microwave?
you have to remove the plug and then the outer casewhich is 4-5 screws on the back,you will find a air duct on the left hand side of the magnetron which is a metal box with two wires on the bottom.the bulb hosing is kept in with a screw and a metal tab,undo the screw and remove the two wires and that is the unit you have to replace,it is called a cap less bulb as it is one unit,reassembly is the reverse.hope this helps regards les
Nov 03, 2014 | Panasonic NN-T990SA Microwave Oven
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
Change the lightbulb on a NN SD967 microwave
I can't find anything in your manual nor can i see detailed pictures of the outside of the microwave but if you see a panel on the outside left of the unit undo the screws to get at the bulb.
Nov 29, 2013 | Panasonic Replacement Part For Microwave...
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic bulb nn a753
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
